alrite~ as promised here is some photos~
really pain in the @rse for uploading here,
I've also upload most of the pics to my facebook album(so much easier to do in facebook~)
http://www.facebook.com/album.php?aid=1688...mp;l=7348c5885a
edit: fixed link.
Edited by Japav
Great to meet up again everyone. Sorry I couldn't stick around for the cruise but promise I won't pike out next time :ninja:
Great photos guys and vid Rianto... good to see you got that dodgy electrician working on Juan's car :ninja:
Edited by scorp
Guys, I will aim if not earlier, in the next Melbourne meet, for a chance to you guys who have factory navi/tv and wanted an english conversion - it can be done now, I am playing with the screen functionality on my car as I am writing this post.
However depending on time (8hr time difference between here & moscow) it may have to be done over 2 days minimum. Ideally is 3pm onwards.
It's an activation based 'service', in which a first part will be installed to generate a unique code. The developer will only activate the unique code through Andy (NSW), Chris (QLD) or me (VIC). This was to prevent 'piracy' so the developer get paid for all their hard work over the past year working on this.
We don't actually give out the disc as each install code is unique to each vehicle's time & location of installation and only usable once, and after it's activated the activation code is of no use to other vehicles, and basically is discarded. So it's not like buying a retail box version of Need for Speed game in EB Games :-)
Due to the time difference with Russia & the time of actual installation, activation can happen on the same day but if timing is not suitable for you then it can be done on a later day. In between activation process you can drive around your car for days without worries.
Ideally we want to go through the process after 3pm in the afternoon as that is the best window of time to get things done with the russian programmer.
let me know when you're in melbourne, pm if necessary, i'll see if I can fit. i'd rather wait till the patch to the DST algorithm is completed so I can install the latest version into yours, but even without it all the screens you need will be functional, and the patch can be applied anytime later.
Hey guys,
new V35 owner here. Picked up my Silver 05 Update Premium Sport last week with 44K on the clock. Live in the south east (seaford), work in carlton. Would love to meet you guys at the next meet.
P.S. Rianto, that was me emailing you earlier tonight about my display screen.
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
