I was reading on g35driver that some of the cars have been experiencing excessive oil consumption leading to a few blown motors. Seems to be mainly with the RevUp motors? I couldnt find much more info than this as most G35s in the US are new and just go back under warranty.
My question is then what models are mainly affected? I am getting an 05 auto so not sure if this comes with the RevUp motor?
Cheers.
https://www.sau.com.au/forums/topic/222918-excessive-oil-consumption/
i have yet to hear from anyone with a V35 that experiences this oil consumption problem
the original poster of that thread is a person with teriible anxiety so taking what he has said isn't a great resource at all, in fact i don't respond to any of his threads because its frustrating to hear his rubbish!
remember that the yanks on g35driver are more likely to make a fuss to get things through warranty.
it may be that the V35s also suffer this problem or it may be that they don't. we dont know as yet. it may be a number of factors that contribute to any potential problem
the only salvage is that at worse case scenario if you need a new engine or a rebuild, then there are more than enough facilities and parts to do so locally. this is one of the things to risk with buying animport with no warranty.
so far there are over 50 2003/2004 coupe owners on here with NO problems at all in regards to engines
The 2003 350Zs reputedly had an oil consumption issue. Since the engines are near identical, aside from the plastic cover and AFM-to-throttle-body intake tract, I would assume they'd earn a similar reputation.
I haven't heard of anything specifically about V35s, though, and the 350Z oil consumption issue hasn't affected that many owners I know.
its yellow i think
if you stand at the front of the engine bay, its just to the right of the oil cap and has a convoluted path to the sump
Thanks, thats the one I was refering to. Any idea where the auto transmission dipstick is or whether one exists?
i assume the 350z engine was assembled in australia? versus V35 engine assembled in japan?
I'm pretty sure the 350Z is fully imported.
Nissan Australia doesn't have any manufacturing facilities after they stopped making the Pulsar down here, so I'm not sure where they'd assemble anything.
Its probable that Australia's cars are on a custom run from a Japanese factory to ensure they comply with our ADRs so perhaps its only our batch that suffers it. I know the 350Z's intake pipe has a resonator where the US one doesn't, and the ECU tune is probably different for our ADRs.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
