Items:
HKS FILTER with adapter for rb25det/
Malpassi fuel regulator/
FET Turbo Timer + Greedy one Both with plugin looms for R33 s2/
Nolethane Front Castor Rod Bush Set R33 s2/
Fermal Flex Turbo intake pipe + intercooler etc 3" size/
Custom Cusco Coil Pack Cover suit s2 R33/
Standard turbo intake pipe for rb25det turbo/
hks?
malpassi reg brand new with guage aswell
fet turbo time ? on car when i bought it
greedy turbo timer 6months old
castor rod bush set brand new just opened plstic thats all to have a look
fermal flex brand new
coil pack cover brand new
stand intake pipe good condition no cracks etc.
Condition:
Everything works fine can post more pics if you like but all the stuff is in good condition.
Price:
hks Filter: $50
malpassi regulator with guage : $130
Fet turbo timer with plug in loom : $50
Greedy Turbo Timer with plug in loom : $60
Nolethane Castor rod bush set suit s2 R33 : $60
Fermal Flex Pipe : $30
Cusco coil Pack Cover : $145
Standard rb25det turbo intake pipe : $40
To Fit:
(What car)some RB's R33's R34's etc
Adelaide South Australia
Contact:
you can contact me here or call me on 0401409575(Allan)
Comments:
i need to sell these item's asap all in good condition will post at buyers expense fell free to ask question etc hope to hear from yas
cheers
Allan
Edited by R334door(s2)
https://www.sau.com.au/forums/topic/223088-random-stuff-for-sale/
  • Replies 66
I have also got a ARC blow off valve too don't know what vehicle its for so i can let it go for $50 will take a picture soon.
with the greedy turbo timer its still in my car can remove and take pic's anytime just not now too cold out side lol.
And with the coil pack cover it is polished.
here's the picture off the ARC blow off valve plum back :
i think you will have to get a adapter made up or something.
with the Castor rod bushes i got where from outlaws speed shop in Adelaide i cant remember what brand it is but it is good quality still got mine in the car and they work great.
Bump.
pm sent
pm replied
Custom Cusco Coil Pack Cover : SOLD Pending Payment.(Till Friday)
link to Greedy Turbo Timer Manual -------> "Click me to download Greedy Turbo Timer Manual"
here is the picture of the greedy turbo timer it is abit dusty because off being tucked under the dash.
Greedy Turbo Timer Sold(pending Payment).
does any one know why i cant edit my 1st post its like the edit button went walk abouts after about 2hrs.?????
Bump
i offer $100 for cusco coil pack cover
no thanks $100 is too low
coil pack cover back up for sale person that was interested did not call or get back to me so its up for grabs
so ill do it for $130 pickup OR $145 delivered anywhere in Australia.
can yous please contact me on my mobile as my internet is down at the moment had to goto a friends place to check and update.
my number is
0401409575(Allan)
cheers
Allan
how long is the peice of thermal flex???
About as long as the keyboard on the computer not certain as my tape measure is at my sisters ill find out after for you if you like.
cheers
Allan
most off the items are still available guys "n" girls except for the.
Greedy Turbo Timer which is sold.
bump
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
