I bought my stagea S2 1998 RS4 S rb25neo about 8 months ago and need some help with sourcing some mod parts for it. Its stock as a rock apart from pod filter. Need more grunt, its hard going from a vl with rb25 conversion pumping out 250rwkw 2 a stagea with about 100 at all fours so i want 2 start with some good mods to make around 200 at all 4's.
computer-is there a plug in type computer for the rb25 neo (best value for money?)
Front mount kits-
boost controller-
cat back system-
front pipe-i have one off a r33 which i used 4 my vl- Does this fit? (x-force)
injectors- (sard or nismo?)
Suspension- what fits the series 2? (back and front) has nismo short springs so i want to use them just need shocks?
Nismo series 2 bodykit-
Volk racing te37 rims-18 or 19 inch
Any other mods that i need to do 2 make around 200kw at all 4's
Thanks
https://www.sau.com.au/forums/topic/223154-stagea-mods/
See Rob at Sabbadin Automotive 9558 4422
I bout mine with only a cat back exhaust since then I did the mods in 2 stages.
Trust Front mount (made for an R33)
Front / dump pipe (cut down R33 one)
Cat
R34 Apexi PFC
Blitz ID3 Boost controller
The above should get you around 200ish rwkw
Then I put on a HKS GTRS which was a direct bolt on for an R33 but needed slight mods to fit the stagea
Bosch 600cc injectors
Walbro Fuel pump, (bosch pump will not fit in the standard pump housing)
Z32 AFM
The clutch is still hanging on and it is pumping out 265 rwkw.
The process was all pretty easy apart from the tuning as Rob seems to think the FPR is on the way out for a couple of reasons.
If you need any more info just ask
Cheers
Dave
https://www.sau.com.au/forums/topic/223154-stagea-mods/#findComment-3931213
im in the same boat, just got my 98 s stock as a rock besides some suspension work and want to try for some more ponies. i only wana spend bout 3 to 4 gs i duno what sturb25s budget is but do you think i should go for those first few mods you done fmic, exhaust and boost controller or wait for more cash.
sorry to sturb25 if i sound like im takn over youre thread but i thought well kill 2 birds with one stone cheers
https://www.sau.com.au/forums/topic/223154-stagea-mods/#findComment-3932825
Cat
R34 Apexi PFC
Z32 AFM
Cheers
Dave
thanks for the advice i was thinking of using a r34 Apexi PFC. easy to tune ive heard. im going 2 slowly do my mods cause i want to do it properly and cash is the problem. What does ur car go like, what year is it.
https://www.sau.com.au/forums/topic/223154-stagea-mods/#findComment-3933647
Dont be sorry man, stagea's are sick cars. i love em. This is my personal opion but i would by ur basic mods first ie: FMIC, Full Exhaust, Pod filter and then save for a decent computer cause ur computer is the heart of ur car and injectors and decent boost controller and then ull be set. Maybe a clutch would be a good idea 2 cause standard clutches arent much chop. To give u any indication on price look up just jap. heres the web address
http://www.justjap.com/
Happy hunting
https://www.sau.com.au/forums/topic/223154-stagea-mods/#findComment-3933674
Happy hunting
yeah thats what i thought, cheers mate.
and yeah my clutch is crap cant even get a chirpy out of it off the line, but otherwise its still flys for a stocky :P
https://www.sau.com.au/forums/topic/223154-stagea-mods/#findComment-3936023
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
