Hey Guys.
Hope someone can help diagnose a problem for me.
R33 with Rb25 with Full exhuast (with compliance cat), Pod, Cooler, Splitfires, untuned at this stage. And boost controller.
I was running a Catback exhaust and a turbotech. Set at about 11psi. Boost levels were as
Stable as ANYTHING. good as gold.
Sent the car in to mechanics get the Split Dump with custom front pipe installed. When i got the car back the first night i blew an intercooler hose first time i gave it any (previously never a prob). Anyways next day i found that i was boosting WAY over the mark. Screwed the controller which was a TURBOTECH back as far as possible. and was getting about 9psi until 5000rpm. then it is creeping upwards with revs marginally over what im willing to let it go to.
From here i proceeded to swap out the turbotech and installed an electronic Blitz spec S controller.
Set at its absolute lowest setting im still getting the same response of creeping once the revs hit roughly 5. and it is telling me Peak boost im getting is 0.80 bar. (I want to aim at about 0.7 straight off the bat as it used to before the trip to the mechanics).
Ive been through making sure all my vaccum lines are connected properly and theres no splits. And i cant find anything wrong. Could the dump pipe be causing this maybe? Maybe im missing something? For 2 diff boost controllers to be doing exactly the same thing something must be wrong elsewhere. Im running out of ideas.
If anyone has any thoughts how i can level the boost out so i can turn the boost up a bit to hit my target and not overshoot, then please share.
Thanks for any help
Luke
https://www.sau.com.au/forums/topic/223434-boost-creep/
because your factory dump and front pipe are really restrictive you will always get around a pound or 2 boost creep by installing a less restrictive exhaust. I got a turbotech on mine and set at about 9 lower in revs will creep out to 13psi on a cold night. sucks
https://www.sau.com.au/forums/topic/223434-boost-creep/#findComment-3936344
You dump pipe could certainly be the cause.
A poorly designed split dump pipe may be interfering with the internal gate, not allowing it to open fully, thus making the boost creep.
To check unhinge the boost actuator off the gate arm. and open/close the gate through it's full 90deg motion, make sure it doesn't interfere with anything and is very loose and smooth to move.
Another problem is: If the split pipe is too small or doesn't merge cleanly with the exhaust pipe, you'll also get boost creep.
I heard too many problems with split pipes (but i heard just as many without faults) and can not justify the gain for the trouble, i have always stuck with a "bell-mouth" dump and have never has an issue.
https://www.sau.com.au/forums/topic/223434-boost-creep/#findComment-3936368
A gain of a pound or two is acceptable 7psi (std) + 2psi = 9psi
His boost is creeping well past his desired 11psi so that's at least a 5psi increase, something else is causing it. From his accounts it keeps creeping with rpm and even has blown his ic hosing off his ic pipes, that doesn't happen at 12psi :blink:
https://www.sau.com.au/forums/topic/223434-boost-creep/#findComment-3936392
When i fixed the cooler hose i found that it was boosting too the moon (guage said almost 20 before freaked and took the foot off) thats when i wound the boost back as far as i could without the nut falling off. Which was when i was getting the results of roughly 0.5 bar from about 3000rpm to 5000rpm. then from 5000rpm moving upwards with revs to 0.8
What i find interesting about this is i have no idea why the controller (turbotech at the time) would have been turned up. I have faith in my mechanic that they arnt fiddling with that.
I might try turning up the boost tonight on the controller and seeing if it hits my goal earlier in the revs then creeps to the exact same level or whether it hits a higher point.
As a quick question. On a Stock RB25 turbo. 0.80 bar boost as absolute maximum in short bursts shouldnt cause any problems? I know its getting pretty close to the limit.
https://www.sau.com.au/forums/topic/223434-boost-creep/#findComment-3936501
  • 2 months later...
Hmmm. update to this thread. Standard Boost Control is back, was creeping upto about 0.80 bar after install. All was well.
Just installed the new Cat convertor. Pick up is noticably improved. Except now even the stock boost solonoid is managing to slip out to around 0.90 bar (Definately too much) and that is without totally winding the revs out.
Can you elaborate on that. i.e Is that the bracket looking part that is attached to the turbo with the rod connected to it?
My other thought is maybe reinstall the stock dump pipe. Hopefully the stocky will fit with the new front pipe. Should do as they welded the flanges on. as long as the length is the same.
https://www.sau.com.au/forums/topic/223434-boost-creep/#findComment-4069438
    • So, I started this repair and got as far as "fixing" the holes with some fibreglass. God all those years working on boats came back quickly. I decided I'd reach out to some rust guys just to see what they would say about it. I came across a guy about 40 mins away and went to see him. He said the windscreen needs to come out, that there might be some more bits around the windscreen and he'd quote them at the time. But his quote was $300 to remove and replace windscreen and $3k for the damage he can see. He said he could respray the roof for $1200 and the bonnet for another $800 (somebody has previously rattle canned it, its horrendous). This is $5300 + any small additional bits. It's a lot, I get that and the name of one of my fave youtube channels 'Not Economically Viable' comes to mind.  I'm not being financially rational, but I've taken him up on the quote. He's opening a new shop in November with more room, so we're waiting for that. I'll leave the currently missing headliner out until then. I'm looking forward to it being fixed and having the paint looking nice again (lots of clear coat issues on the roof too). / flame suit on.
    • Oh and some up-and-comings; New rear drivers wheel bearing. I'll do that this weekend while the diff is out. The car is already up and the d/c axles and missing exhaust will help with space. This is the last bearing for me to do and I've been dragging my feet on it. I also have some new EBC blue stuff pads for the car and some new brake fluid. I haven't ever flushed the fluid in this car and looking forward to it. I have 600 degree fluid to put in. Not exactly "race fluid" but better than the typical stuff I have been using.
    • A proper clutch/plate type mechanical diff with quite a lot of pre-load and high locking % is better for drifting. Much more consistent in its behaviour. A helical can be annoyingly vague and inconsistent in how it responds under the sorts of abuse found in drifting.
    • Some updates here. I pulled the entire interior out, minus some trim to respray the seats with Colourlock dye. It turned out really nice though I accidentally let the dog in the car after and she scratched up the front seat.  This is what it looked like before, the colour was just washing out everywhere but thankfully the leather was in good nic. Then after the respray   And after the bloody dog jumped in The headliner is out waiting to be retrimmed, but it will stay out now until Nov - see why below. I replaced the stereo/headunit with a period-styled Android headunit. I have no after pics, but I'll get some. This is because of the missing pixels. I tried to fix this twice with replacement ribbon cables but couldn't. Also the bluetooth interface I'd bought for this was crap. Then there's the rusty roof. Pics and info in this other thread. I have decided to get this repaired professionally, but I'll update that thread. This is why the headliner will stay out for now. I'll be getting the roof and bonnet resprayed at the same time the rust is fixed. I also had an interesting issue with my drivers door lock.  For a small period I was having issues getting any 12v power to the car - I mean *any*. It would have no dash lights, nothing. It happened while I was at the shops and I couldn't get in the car. So, we had 2 problems. The most pressing here is that I was locked out. I have only a single physical key hole on the car, the drivers door and no amount of turning would unlock the car. Surely it doesn't need power for this? The second issue is why am I losing all power periodically, The battery isn't dead, its almost like the battery isn't even there. Two issues that were surprisingly easy to fix. You fellow BMW over-engineering lovers will appreciate this. The lock in the door has 5 states; mechanical lock, electric lock, neutral, electric unlock, mechanical unlock achieved at -90 degrees, -45 degrees, 0 degrees, 45 degrees and 90 degrees. Although, the unlock is towards the front of the car, so opposite for LHD countries. Sticking the key in and turning 45 left or right is what is used 99% of the time. It activates the central locking etc. 90 degrees is for dead battery access and, obvs, only un/locks the one door. But because the mechanical lock is never used and is 27 years old, it seizes up. I was totally unable to turn the key far enough to get to the mechanical unlock (At the time of locking myself out, I didn't even know this was a thing). I eventually did it with some vicegrips and teflon spray.  I made a quick vid for other E39 peeps.   The battery issue is totally new to me also - It wasn't making sufficient contact between the post and the terminal. The terminal was bolted on tight, but the car wouldn't have power. After checking the battery with my multimeter I accidentally contacted the terminal and the battery post and the car got power. The battery was only a few years old and in good condition. I cleaned the post and the terminal with a wire brush, bolted it back on tight and never had the issue again. I'm still surprised that despite having solid contact it didn't work. Also, the car was getting Warragamba sized pools of water in the back when it rained. My initial concern was another rust problem. But when I went out on Weds while it was raining and while I had no headliner in I could see a steady stream of water coming through the roof mounted aerial. As this aerial is for the (now removed) car phone I pulled it out and whacked a blanking grommet in the hole. It seems fine now. I'm thinking I might get the hole permanently filled when the rust is fixed. Moving forward and things in progress; The tailgate needs some attention. I have taken all the trim off to clean it all and address some small rust spots. I have partially done all of this but I'll finish it up hopefully this weekend. As all the trim are now entirely devoid of trim clips I have bought a heap of strong velcro and I'm hoping it does a good enough job as any of this trim in good condition is super expensive and usually in Europe as we dont have many of the wagons here. Suspension and brakes!!! This is exciting. In the front; New control arms New sway bar links New lower Eibach springs (the only modification I'm planning on this car) M Sport shocks (these came with the car and will replace the longer shocks in the car) New top mounts Used 540i calipers (stock brakes suck!) New 540i disks and pads (22x296 mm for 528 and 30x334 mm for 540i) New front wheel bearings (thank all that is holy for bolt on bearings!) Annnnd in the back; New control arms New sway bar links Adjustable air suspension arms (fool the car into what the current height is so the self levelling suspension can match the new front ride height) New ball joints I'll also be doing a brake fluid flush while I'm in there. I'm planning on switching the car over to the 16's that came with it so I can clean up and respray the M Sport 17's. They've lost a lot of colour over the years and have some gutter rash. None of this will start until the E90 is back.
    • You mean you will regret it for drifting duties? I don't quite follow.
