Hi all
When that weird sticky fluid starts oozing out of the back end of your skyline and/or the rear end wriggles under acceleration/brakes/cornering then it may be time to take a look at your subframe bushes - mine were rooted.
I have purchased some noltec subframe bushes to replace the old ones from motor spares. I will also be getting some diff mounting bushes (UAS), whiteline subframe alignment bushes (pinapples) to firm up the rear end.
Anyway its a big job and to add the the large body of information already available on SAU (search subframe bushes, R32, etc) i though i'd add some pics as i do the work.
The first round - below.
HICAS ram as attached to rear subframe at back of diff. Note the bushes at the top of the pic, these are 2 of the diff mounting bushes that will likely be replaced.
Edited by OzLeroy
https://www.sau.com.au/forums/topic/223441-r32-gtr-subframe-bushes/
As you will likely have read elsewhere, you will need to remove wheels, calipers (via 2 bolts + 1 bracket on hub). The only other item off the hub that needs to be removed is this bolt which attaches the springs/dampers to the hub. It is not necessary to remove the upper control arm to hub bolt as in the pic.
It is possible to leave the HICAS system and diff (once primary drive shaft is unbolted) in situ, but i wouldn't recommend it the subframe assy is heavy enough by itself. HICAS should be ok to leave on though once the hydralics are disconnected.
The upside down subframe assembly including upper links +lower arm (visible), hubs and discs. HICAS ram removed. The steering rods attach onto the stubs from the hubs which are visible in the pic. The stubs on the lower control arms are where the anti-roll bar mounts. NB - be careful not to damage these when handling the subframe!
Subframe was removed using 2 jacks (pictured earlier).
Diff was removed using 1 jack and 2 loops of rope going over the subframe, one across the front of the diff where it attaches to the primary drive shaft and one at the back through some pronounced cooling grooves which run along the underside.
You can clearly see the 4 big holes where the subframe bushes used to sit, one is still in place.
Notice the use of expert trolleys :)
One of the subframe bushes. This is one of the silicon fluid filled ones at the front of the sub-frame.
Firstly we drilled out the rubber (and silicon filled) part of the bush between the inner and outer metal rings. Used a hole saw to start but you will require extra long/deep holesaw to get all the way through. So i followed up with a normal drill bit and simply lots of holes. Then use a large screw driver and a hammer to push through the rest of the rubber/silicon crap. Then hammer out the inner metal ring. Then its hacksaw time :) .
Beware the silicon filled front bushes have a double layer metal skin at the outer edge which needs to be hack sawed through - a major pain in the bum (or lower back to be more precise).
Even though 1 of these bushes was buggered they were all still exceptionally annoying to remove and seemed to have relatively intricate internal construction (for a bush at least!). This did make me wonder if i should have got a quote on the OEM nissan replacement - these ones did last ~15 years. How long have the noltec ones need tested for? She'll be right.
One front silicon filled bush with centre metal ring removed. Hack saw in place and ready to cut.
We made 2 cuts through the outer metal ring (one is visible in the pic), then forced out the section made free by the 2 cuts with a long screwdriver/chisel + hammer. Then the rest of the bush can be removed using the same technique. Once one section is free, the bush can be removed fairly easily.
One of the rear subframe bushes. These have a solid rubber inner section which makes them a bit easier to remove. There seem to be subtle differences in the structure of the front and rear subframe bushes.
Note cooling fins on the back of the diff, do i have a Vspec or is this normal? chassis number says no, but i also have bilstien suspension.... no brembos....
My diff got fins too.It's normal. Bilsteins you can buy quite easily.
Done the rear cradle on mine too. I had access to a hoist and a 50 ton hyd press, it was fun!!!
No more loose feeling back end FTW.
Great writeup, I was thinking of doing this in about 2wks time by myself. The subframe sounds fairly easy to remove but the bushes sound line a PITA to remove/replace. I might be better off taking the whole subframe to my local suspension shop and getting them to replace the bushes for me.
my bushes werent rooted but i put in the alloy bushes on the rear subframe to pretty much solid mount it to the chassis.
didnt notice much more road noise and the rear end feels heaps more stable.
they were easy to put in as well
Yeah, the alloy bushes sure are tempting, oh well, too late for me now. There are trade-offs but they would be so much easier to install and i imagine they'd eliminate a significant amount of subframe movement. I think anyone considering this job should go for a ride in a car which has alloy subframe locks mounted to get an idea if the NVH is tolerable for them...
Edited by OzLeroy
it honestly made hardly any difference for me.
If the interior was stripped out i'm sure a whole lot more noise would come through but with the sound deadening and
all the interior in i could hardly tell the difference
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
