  • Replies 61
Posted Images
DRD-00F, nothing to say tonight??? ha ha
aw man, I was watching the game with mates tonight! Not sitting behind the computer! I haven't had the net at home for 2 weeks... kinda got used to it :)
but yeah... SmashT!
like... hardcore...
Re-match?? :(
https://www.sau.com.au/forums/topic/223447--/#findComment-3936647
it was meant to be... NSW was meant to loose... these games are great revenue.... had we kicked arse.. (and we could have kicked some redneck pussy) no-one would be THAT interested anymore.. but, for what it's worth ... Congratulations...now, get ready to have your asses handed to you soon.
THAT, is all.
https://www.sau.com.au/forums/topic/223447--/#findComment-3936752
