I just installed my FMIC on the weekend
The day after the install had had two joiners blow off when under a full load, So that night i reconnected all the pipping tightend all of the clamps really tight then last night the rubber(stock)90 degree bend which runs from the passenger side of the cooler tore straight down the seam when running around about a constant 10 psi for a couple of seconds.
Has anyone had a similar problem when connecting a after market cooler to the stock hoses.
Where abouts can i get a Silicone 3'' silicone bend from and will it be any better than the stock nissan rubber bend?
https://www.sau.com.au/forums/topic/223557-silicone-bends/
it accually allready has a lip around the edge of the pipe its from Just jap if you are familiar with the kit.
its more the fact that the bend split down the middle(not sure how common it is)
Now i have to cut the front indicators farkin why cant everything just fit
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3938869
i seen at supercheap 90 degree silicone bends that are heaps longer than the stock piping if i put that on its sure to stay put.*fingers crossed* since installing it on Monday i havnt even been able to boost without something F!@#ing up
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3939305
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
