I just installed my FMIC on the weekend
The day after the install had had two joiners blow off when under a full load, So that night i reconnected all the pipping tightend all of the clamps really tight then last night the rubber(stock)90 degree bend which runs from the passenger side of the cooler tore straight down the seam when running around about a constant 10 psi for a couple of seconds.
Has anyone had a similar problem when connecting a after market cooler to the stock hoses.
Where abouts can i get a Silicone 3'' silicone bend from and will it be any better than the stock nissan rubber bend?
https://www.sau.com.au/forums/topic/223557-silicone-bends/
it accually allready has a lip around the edge of the pipe its from Just jap if you are familiar with the kit.
its more the fact that the bend split down the middle(not sure how common it is)
Now i have to cut the front indicators farkin why cant everything just fit
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3938869
i seen at supercheap 90 degree silicone bends that are heaps longer than the stock piping if i put that on its sure to stay put.*fingers crossed* since installing it on Monday i havnt even been able to boost without something F!@#ing up
https://www.sau.com.au/forums/topic/223557-silicone-bends/#findComment-3939305
    • Did you take the MX5 for a Blat around the Track at all?
    • LOL, "they said it might be slippery"..... 30 seconds in your off, 60 seconds in white twin backs into the corner That new track looks good, and the Datsun was chopping cars quite nicely
    • I'll get one of these also just for giggles
    • I bought 6 new spark plugs to compare readings. They will be here tomorrow and ill see if meter is far off if it all. I know one is at least reading 0 so its best replace all anyway if one is bad, from experience. I still have to test the harness just to be sure its not a double issue and I waste my time haha-the old plugs are iridium I always thought those lasted more than 50,000 km.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
