Hello
I put a RB25 turbo on my RB20 and it works good, but now I have a lean problem. People smelled the cars lean smell(huh??) but apparently my car is running lean. I had my O2 sensor checked at Nissan(I live in Japan) and the results came back that the sensor is good.
I took off my cat today and someone checked it for me, and I had a look too. There is a 1inch-1 1/2 inch diameter visible space from one end of the cat to the other. Mechanic said that my cat is badly clogged and I need to replace it. He said I can still drive and boost but don't race anyone and don't try to hit high boost. The mechanic also suggested that I should get a bigger fuel pump to allow the car to have more fuel since I have a bigger turbo on there and my car is running lean. I smell it too
The mechanic knows his stuff, so I am wondering how long should I run with a dirty and clogged cat and whats the longest I should wait until upgrading the fuel pump?
Help
Edited by 335
quick fix for your cat is take it off and take all the stuff in the middle out then put the cat back in onto the exhaust.... it will stop any issues you are having till you can get a new hi flow one.
fuel pump - just get one from an r33 turbo model should cost you next to nothing..
So I do need to replace the fuel pump with a higher flowing one? So the 33's fuel pump is bigger? My friend has a R33 that he is junking, he was trying to take out the fuel pump, but we couldn't figure out how to take the assembly out to get to the pump.
I am tempted to get a Nismo 555cc fuel pump. Over kill?
Help
Bosch 044 pump, mine cost ~$200 and the same again to have a pro fit it and rewire.
Fix the cat pretty soon mate, with a blockage like that your turbine housing will be getting pretty damn hot (I had a blocked cat ages ago and it was making my exhaust housing glow white hot pretty quickly) and ceramic turbines don't like excessive heat :)
it shouldnt matter what turbo you have on there, due to the fact it is the AFM that measures the air flow and inputs the correct duration the injectors are open for.
just because you have changed turbo's doesnt mean it will run more boost than your old one did...unless you make it ofcourse......i.e.....waste gate actuator.....
factory ecu will boost cut at 16 psi on a rb20det, the fuel pump can handle that, really all you need to do is get a better fuel pressure regulator so it isnt really the issue here,
take the cat off and smash the center out of it, and put it back on, i think you may find that is the issue.
especially if you had to change your turbo cause the old one was shagged.
Factory ECU will NOT boost cut at any particular boost level.
It is an AFM over-voltage cut and for me on my RB30 (w/ 25 turbo) on standard RB20 ECU that was 12psi with anymore than 3500rpm or 10% throttle.
Fuel Pressure Reg. is BS. Put a decent fuel pump in there and it will be fine.
Edited by bubba
factory ecu,rb25 turbo(stock) 3" turbo back zorst i seen it hit 24psi before it blew
an intercooler pipe off.So i find the above statement incorrect.
^^ agreed.
And I'm sure a GOOD CONDITION stock pump would be fine but these things are 18+ years old and the pumps are getting pretty tired.
Put a Bosch 040 or 044 (preferably) in the tank and rewire it, you'll be laughing.
So I need the fuel pump for sure, this pump is from another junk car when mine died last year. So that means this pump will go any minute?
So new cat, new pump and I should be good?
If I am lean why did my 02 sensor test come back good? It did read lean on one of the catergories but the final result said working fine.
What is the longest time I should wait to replace the pump and cat? Which needs to be changed first? Is the X-Force High Flow Stainless Cat any good?
Thanks
    • Hi guys, Making some space/cleaning up. A whole heap of random OEM R33 GTR parts and other random bits and bobs. I will update this thread as I go. Parts are located in Moorebank NSW 2170. Pickup preferred but will post at buyers expense. Prices are negotiable. If they don’t sell it will go in the bin. Item 1: BOV return pipe. $40 Item 2: RB26 cam gears. $20 Item 3: R33 GTR torque split, oil temp, boost centre gauge. $100 Item 4: RB26 fuel rail x 2. $20 each Item 5: RB26 Recirc valves. $50 Item 6: OEM upper front arms. $20 Item 7: Royal Purple Max Gear 75w-140 1 quart/946 ml x 5. $50 each or 5 for $200. Item 8: OS Giken 80w-250 diff oil 1 litre. $25 Item 9 Eibach springs. ers-11-140-60-0140. $100 https://www.streetfx.com.au/eib140-60-0060-eibach-ers-140mm-length-x-60mm-id-coil-over-spring?_ga_campaignid=22235933977&_ga_adgroupid=180146800292&_ga_keyword=&_ga_device=m&_ga_target=pla-295238231169&_ga_locint=&_ga_locphy=9071723&_ga_matchtype=&_ga_network=g&_ga_device=m&_ga_placement=&_gcl_id=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE&gad_source=1&gad_campaignid=22235933977&gbraid=0AAAAADPiTbo1xAuvnjIWWYnezivf-BUSY&gclid=CjwKCAjwlt7GBhAvEiwAKal0cvkVE_hstv24cDiaICsIk1oznH9zAoJf3By6vR3Tpe7jmByqM6JFHBoCZYAQAvD_BwE
    • That's kind of what I was getting at saying you'd be here soon regarding length etc being able to add additional restriction.  My assumption (possible donkeys of you and mption) is that the length of hose to an oil cooler, and back, isn't going to be that huge of a loss. Typically you're talking about 1.5m of total length. And so far everyone in our world hasn't had issues with oil not being able to get to a cooler and back, it's more been, how the heck do we get the oil out of the head and back down to the bottom? I'd nearly hazard a guess the biggest issue people have with oil cooling and oil supply, is being able to get the heat out at the cooler itself (not enough air flow, too small of a cooler etc) Also, when people mount them wrong and make really awesome air traps so they've dramatically diminished the cooling capacity.
    • I will rebutt this and the preceding point from Dose....but without doing any calcs to demonstrate anything and without knowing that I am right or wrong. But... The flow capacity of a fluid transfer system is not limited by the smallest orifice or section of conduit in that system, unless it is drastically smaller than the rest of the system. OK, I use the word drastically perhaps with too much emphasis, but let's drill down on what I really mean. The flow capacity of the system is the result of the sum of the restrictions of the entire system. So, to make an extreme example, if you have a network with 3" pipe everywhere (and let's say a total length of only a few metres) and that 12mm ID restriction of the oil filter connection being the obvious restriction, then for any given amount of pressure available, the vast majority of all the pressure drop in the system is going to occur in the 12mm restriction. But.... increase the length of the 3" pipeline to, say 1000m, and suddenly the pipe pressure loss will likely add up to either be in the same order of magnitude, possibly even exceeding that of the 12mm restriction. Now the 12mm restriction starts to matter less. Translate this to the actual engine, actual oil cooler hose sizing, etc etc, and perhaps: The pressure loss caused by flowing through the narrow section (being the 12mm oil filter port, and perhaps any internal engine oil flow pathways associated with it) is a certain number. The pressure loss through, say, -12 hoses out to the cooler and back is negligible, but The pressure loss through -10 hoses out to the cooler, at the exact same length as the above, starts to become a decent fraction of the loss through the 12mm stuff at the filter port. Maybe even it starts to exceed it. I could actually do these calcs if I knew 1) how much oil was actually flowing in the line, 2) gave enough of a f**k to do things that I hate doing for work, voluntarily for a hypothetical discussion. Anyway - I reiterate. It's not the narrowest port that necessarily determines how much it can all flow. It is the sum. A long enough length of seemingly fat enough pipe can still cause more loss than a semmingly dominant small bore restriction.
    • To pick up what Dose is putting down. Not a lot of point running a huge hose if the motor is still restricted to the smaller size... It's only capable of flowing so much at that point...   *Waits for GTSBoy to come in and bring in the technicalities of length of pipe, and additional restriction from wall friction etc etc*
    • Hooley Dooley these things have some history! If i sell them they will need a certificate of providence to prove they have been in the hands of verified RB20 royalty! They have been stored in a plastic tub, away from sunlight and moisture. They are in mint condition. And they will stay that way, as i have sprung the money for a set of shockworks coilovers. I'm just working on getting them in at the moment, after rebushing the rear of the car, and while the subframe was out i welded in the GKtech reinforcement bracing as well.  They will get a workout at Ararat King of The Hill in November. I ran 48s on the short course there a few months ago, and i am hoping with new bushes and shocks in the rear i can launch a bit harder. There was a fair bit of axle tramp when i tried too hard off the line. a few of the corners had dips mid way which also made the car feel a bit unsettled, hopefully this will help there too.
