Hi everyone,
jus need to know of a good mechanic that's pretty trustworthy (ie. wont fudge anything else up to get more business outta me.. lol) an has pretty a pretty competitive price, I love my car an like most people on this forum, I want what's best for it..
I live around the St George (Brighton) area an it would be good to find a local, although I don't mind travelling (as long as its not too far)..
Please lemme know if you got someone good out there, your help is much appreciated..
an thanks again in advance.. :thumbsup:
https://www.sau.com.au/forums/topic/223746-need-a-new-mechanic/
IS motor racing Unit 5, 5-7 Bermill St Rockdale NSW 2216 TEL : 02 9599 9918 .... oppisite fitness first west botany steet in that side street (there is a little corner shop on the corner) in the little complex there.. perfect for u, its in ur area, they specialise in jap imports and they are one of the best around. i have always taken my cars there and so do all my mates. excellent work higly recomended!!!
Would recommened RICOL automotive at peakhurst.
probably the closest one to you :(
Excellent work and they wont rip you off. Have done plenty of work thru them over the years. They have set rates/per hour as well
my mate's on his 2nd warrenty rebuild from them, personaly i'd travel for a GOOD workshop, price and how close it is should come 2nd and 3rd. my 2 cent's
IS is good i've heard, even my mechanic reckons indy is a top bloke
I goto Maytech though, all the skylines i had and this car now are all taken care by Mayan, his workmanship is top notch, and i can safely say the cars he worked on, are all put back just as good as how it was from factory, no missing bolts, no missing covers here and there...
check out that red R32 GTR in the workshop which he rebuilt from ground up... sexiest thing i reckon..
I have had some work done at this two places and if you have not selected your tuner then UNIQUE AUTOSPORTS, CRD is great choose.
I would do this, call and tell them what kind of power you want and decide which one will offer you the best chance to reach your goals
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
