Hey guys,
looking to buy a proper seat/rail setup for my G25 wheel..
Basically just want a simple seat and the rails to support the wheel & pedals..
Not really wanting to spend much more than $200.. let me know!
Thanks.
P.S im in melbourne
https://www.sau.com.au/forums/topic/224065-gaming-seat-for-g25-wheel/
I know a guy selling 2 fixed back seats for $300ono....they're no name and yellow, but would be perfect for a steering wheel setup...find someone else that wants to make a setup and split the cost of the seat, then make the rest up yourself and you're set.
let me know if you're interested and i'll put you onto him
there disgusting.. id prefer to pay another $100 or so and get one of the proper car race bucket seat setups... but i just dont know where to buy one from?? Or the best/most trusted site to buy them from..
ive been holding onto a 33 drivers seat and rail for a while to make a console. been holding off cause bunnings wont cut mdf because its carcenogenic and ic ant be bothered buying tools.
finally found a woodwork place that i can hire out so i may just get this done after all..ha.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
