Hi guys,
MY R33 has been with my mechanic for the past month trying to solve a mystery of why the injectors have been hitting 100% duty cycle after 6500rpm. We tried everything including a new ecu etc etc. While my mechanic took it for a drive on a really hot day approx 33 degrees he noticed that the intake temps shown on the power fc commnader were going ballistic and hitting 90 degrees which sounds pretty destructive. From that he has sussed out why the njectors go mad. It seems the Power Fc reverts to a correction map high up the RPM range to prevent detonation. We are now stuck to why the inlet temps are going mad. Intercooler is fine, etc the only things being wrong are the rad cap being dodgy and leaking at high temps. He said that it may have something to do with it but im not sp sure.
Anyone got any ideas???? Any help appreciated.
Cheers
Gez
https://www.sau.com.au/forums/topic/22410-crazy-intake-temps/
Hiya mate,
I bought the car as it is. From the looks of things it has std turbos which may have steel internals, Intercooler doesnt have any signs of a make on there but it looks like a Trust unit, it has 260 degree cams. I took it to GTART (uk meachnic) to have the car mapped and it got 467bhp at the crank @ 0.9 bar and 95RON petrol. We later tried 1.2bar boost and got 505bhp but the injectors were going mad so we aborted the 1.2bar map. We later noticed that the car didnt have a thermostat which was weird. We have now also noticed that the rad pressure cap is dodgy as it leaks every time someone lays a finger on it when its hot so it looks like its not holding pressure. It seems that the car was running high bhp back in japan as a load of bits have been taken off like the uprated rad, load of guages and turbos.
I dont really fancy running 90deg intake temp as the engine will just go pop so need to fix it as the car does drive really nice.
Any help greatly appreciated.
Cheers
Gez
Ok, this is where it gets more interesting, there wasnt a thermostat in the car when i got it from Japan......It aint doing the car much good coz when it gets too hot the Power FC goes into a correction made and fires the injectors at 100% in order to cool the engine down little to prevent detonation.
Gerry
never seen a car without a thermostat? what kind of petrol head are you? If only you knew just how many cars deliberatly remove them before going on the supercruise around natex come summernats time.....
Guest INASNT
y would u remove it?? so that the comp doesent go into safe mode when the car overheats?
He is talking about air intake temperature.
The leaking radiator cap and lack of thermostat (not thermostat housing that i think you are thinking of INASNT) are unrelated to the high air intake temperature. The car will not overheat with a leaking radiator cap unless it runs out of water (or gets close to) hence why the guage is normal. People remove thermostats (like bl4ck32) to stop the flow restriction and keep the coolant flow at a decent speed. When removed the vehicle takes longer than normal to get to normal operating temperature.
As for the excessive air intake temperature it could be many things such as blocked or damaged intercooler or a collasped hose or blocked filter/s.
With a GTR with the front mount (of that size) the intake air temp really shouldn't rise over 60 degrees, on my car i can't remember the air intake temperature ever really getting over 40 degrees and i have had sub zero temperatures registered (i live in the mountains).
Do you run exposed pods in your bay because that could be the start of the cycle.
Also if the car is running lean (you mentioned the injectors maxing out) this increases overall operating temperature of the combustion process.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
