Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh well you see that ummmmmmmmmmmmmm yerrrrrrrrrrrrrrrrrrrrrrr but they WEEEEEEEERRRRRRRRRRRRREEEEEEEEEEEE just so GOOOOOOOOOODDDD!!
  • Replies 300
Pete, Leigh said he would be very happy to wash your bike for free!
Careful, careful.....I might hold ya to that!! :D
NOTE: If you wanna wash your car or get my mates to wash them for you (note you have to put the money in the machine haha)tomorrow i reckon we should catch up at the new BP on Port Rd :) 2PM! WASH YOUR CAR DAY!
I have to do mine in the morning because of a mates wedding tomorrow arvo otherwise I'd probably join you
well dstroy, jenkies, damo, min are all meeting at mine tomorrow night to go to the meet spot and thats all sorry then me and damo's new girl are going to hq so we will be all dressed up lookin hot and stuff
Mmmmmmmm ... hot women! :D
Good luck to everyone going - every idiot and his dog is going to turn up to this one, and it is going to be wild. When the cops get involved look out.
Yeah thanks for the support Andrew, we will see how it goes then you can start criticising!
hehe I was just having a friendly stab :( .... we get along just fine :D
I am still under the impression that Kahli didn't take the advice of many people's posts in this thread to change the meet spot from the MySpace advertised one. If that is the case (which I think it is) then it will be an interesting cruise. That is all :) .... didn't think I was being particularly negative - I even wished you luck!
how many stags are going to be at the meet tonight?>
1 ... as always! :D
I'll change my sig to "The lonely Stag" :)
Altho it did get some attention :(
Edited by RubyRS4
Just got home from meeting up with the cruise after I finished work (11:30).
Good to meet some new people, and have a bit of a strap through the hills in the process.
There were only a few left on the cruise by the time I met up with them since apparently people can't read cruise sheets. My excuse for leading people astray was that I didn't have a cruise sheet :)
Anyhow Cheers to all involved;
Oh and by the way happy birthday Kahli :banana:
think some people accidently followed me when i was just heading home :banana: i turned down a random side street after i relized so they got the idea this wasnt the cruise
i just rolled up for the initial meet n greet n decided ive spent enough $ on petrol this week, not a bad turnout seen it was mainly skylines that showed as aposed to random v8s
Edited by Inline 6
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
