Make:Mazda
Model:1996 Mazda 626
Kilometers: 148,000
Transmission:Manual
Colour:Metallic Dark Blue
RWC supplied: Yes
Currently registered: Yes
Price:$5500
Contact: John 0432364016
Comments / Modifications:
The car has been in the family since near new, always looked after and treated well. Being a 1996 model it is the last of its kind with the rare dark blue exterior and factory blue stitch bucket seats, the interior is it immaculate condition with no rips, stains or imperfections whatsoever. Exterior is also in good condition with no damage or fading of paint or seals, the car is completely stock par from tinted windows which have a 10yr warranty done in 2005. These cars have a good reputation for comfort, performance and reliability. A must see for this price with low kilometers, selling due to upgrade and have no more room for it anymore. Price is neg. for serious buyers
Images:
https://www.sau.com.au/forums/topic/224358-for-sale-mazda-626/
  • 3 weeks later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
