  • Replies 182
Geeze nobody tell me about this thread or anything.... :)
Ando mate if you can't make it tomorrow nite than the original skank hunter might need to make an appearance :D
Umm could the meetup point be any harder to find than what it is on www.whereis.com.au ? Its about 16 pages for me and 47 roads.
I'll let ya's know 2moro if i'll be in attendance as I know alot of you are hanging out for my final decision. :uh-huh:
