  • Replies 123
Posted Images
well im out wont have my car back till monday now :):( will be there and driving next time for sure so plz keep me posted about the next one :cheers:
Sorry to hear Adam - I'll let you know when I am out next. I'm away a lot for work but I will go out at every given opportunity!
Wheres a good spot to get a Cams approved helmet from?
Go for Revolution Racegear or Autosport - but you can use ADR compliant helmets, which generally means you can use most if not all motorbike helmets.
Any helmet with the ADR approved sticker will do Luke.
Depends how fusssy you are on a helmet but you can spend anything from $50 to $1000 for a helmet.
had such a good time today, most fun i've ever had behind the wheel of a car. Farstest lap i did was a 1.25 on my street tyres. Thanks to Andy for the advise, it definatly helped me. The car ran perfect all day, untill i had a look at my front brakes :ermm:
Yay for cross drilled rotors on shitty metal. What brand rotors? I usually only go slotted but have to make note of what x-drilled rotors get fatigue like that....
-D
Was a wicked day - ran a 1:17:01 as the quickest, and no matter what I did I couldn't crack a 16!!! Was great to get back on the track again - Dstroy did really well to keep that beast on the circuit with all the sliding around you were getting!!!!!!
what tyres & pads were you running Andrew and how much oil were you putting in the catch can on average.
I was running a fairly worn out set of RE55s bridgestones on 33GTR rims - 255x45x17. Brake pads are street spec at each end, although I do have AP brakes at the front, braided lines and brake ducts too. I didn't have any issues with oil venting into the catch can - but I never have. I reckon it might have collected maybe 100ml over the course of the day (6x15min sessions).
Can't wait to get out there again!!!!
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
