Item: Uniden UBCD396T Hand Held, 6000 Channel Digital Scanner
Website: www.SkylinesAustralia.com
Item Condition: NEW
Price and Payment Conditions: $500 $450 $400 ONO, Trades Welcome (COD)
Extra Info:
Digital Programmable Handheld 6000 Channel Scanner with Digital Remote Control Head Accessory
This handheld digital scanner with full frequency display offers 6000 programmable memory channels is now bundled with a digital remote control head accessory. The UBCD396T-RH96 with TrunkTracker IV™ Technology, offers APCO 25 digital capability, allowing users to monitor the activities and signals of city and government service departments, utilising advanced scanner technology in an all new compact handheld design. Uniden's UBCD396T is poised to improve interoperability between large cities currently using the digital systems and those that still operate on analogue systems.
Offering the new Ground Breaking Technology "Close Call RF Capture Technology" this scanner automatically "Listens" for any nearby or "close" transmissions and once they occur the scanner immediately tunes in to this frequency which is ideal for use at events or locations when the transmission is unknown. The UBCD396T-RH96 is a state-of-the-art scanner radio with TrunkTracker IV™ and automatic scanning capabilities. You can store frequencies such as police, fire/emergency, marine, air, amateur, and other communications into the scanner.
You can carry it with you wherever you go, use it at home as a base unit, and with the addition of a remote control head accessory it is ideal for in-car use. You can use the scanner's scroll control to quickly select channels and frequencies. You can also use the scanner's scroll control to quickly select channels and frequencies, or similarly automatically program channels in a system using the Auto-Store feature.
Suggested Retail: $999
Key Features Designed and Engineered in JapanSpecially Certified for Australian and New Zealand Market6000 ChannelsUltra Compact Design: Convenient and ergonomicClose Call™ RF Capture Technology: Allows you to immediately lock onto nearby transmissions. If someone transmits nearby the scanner immediately detects and tunes in to the transmission. Ideal for use at events when the frequency being used is unknownTrunkTracker IV (Motorola APCO 25 Digital, Motorola, EDACS, LTR)Backlit Display and Keypad Pre-Programmed Service Searches
- Police
- UHF CB Radio
- Marine
- Railroad
- Air
- CB Radio
- Racing
- TV Broadcast
- FM Broadcast Alpha
Tagging100 Quick Key System AccessBand Coverage - 25MHz to 1.3GHzAudio AGCAutomatic Digital Threshold AdjustmentSearch with ScanDCS/CTCSS Rapid Decode - Instantly Detects and Displays the Subaudible Tone So You Can Quickly Determine the System SettingsPC Control
Additional Features:External Jacks – ANT: SMA TypeInternal Speaker: 8ohm.1WMax Search Speed: 300 Steps/secOperating Temperature: -20° - +60°c Size of Unit (mm): 61mm(w) x 31mm(D) x 136mm(H)Weight without battery: 181g
Taken From http://www.uniden.com.au/AUSTRALIA/p_ubcd396t_rh96_index.asp
Pictures: http://www.uniden.com.au/AUSTRALIA/p_ubcd396t_rh96_index.asp
Contact Details: [email protected]
- Police <----- ENCRYPTED
- UHF CB Radio
- Marine
- Railroad
- Air
- CB Radio
- Racing
- TV Broadcast
- Fire
- Ambulance
- RTA
- SES
Cant edit first post,
The Unit DOES NOT come with the head accessory <--------------------------------------
Price drop $250 ono , Will also accept items of interest !!!
I Will locally deliver (Liverpool area,campbelltown,bonnyrigg)
  • 10 months later...
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
