1993 Silvia specifications
Fitted with 1994 Rb25
Rb25 gear box, with short shift
Custom made forged pistons, from the USA
Compression changed to suit pistons
Fully balanced
O ringed block
Major head work
275 HKS cams
Custom cam gears
Greddy plenum
Q45 throttle body
Custom large aluminum radiator
Huge FMIC
Large Greddy racing BOV
Power FC with hand controler
5-stud conversion
GTR brakes
Performance brake pads
Nismo wheels (17x8 and 17x9)
Brand new tires 235/40 255/40
GTR diff
HKS 2530 turbos (fully rebuilt, and high flowed)
HKS dumps
GTR front pipes
GTR turbo manifold, and pipe work
HKS 4inch super dragger exhaust
High flow cat
1000cc Sard injectors
300zx AFM
Apexi pod filter
3/8 fuel lines
Big competition fuel filter
Malpassi fuel regulator
Nismo Speedo
Map sensor
5-point roll cage (andra spec)
Odyssey battery
Strut brace
OS Giken twin plate clutch, and flywheel
Greddy turbo timer
Custom center dash gauge pod
HKS fuel gauge
HKS oil pressure gauge
HKS boost gaugec
Custom catch can
Shift light
GTR brake master cylinder
Veilside front bar
Veilside side skirts
Trail rear bar
R34 rear wing
Recaro cram leather seats
Koni fully adjustable suspension
Momo steering wheel, and boss kit
Momo gear knob
5-point harness
Alpine head unit
Alpine 6 stacker
Nismo oil filler, and radiator caps
Dark tint
Polished cam covers, and pipe work
The car has been resprayed in its original black
Flared rear guards
All modifications have been blue plated, and transport approved.
Quite easily one of the fastest Silvia’s in Australia, and is up the with the higher power’d Rb25 motors in Australia.
Best time is an 11.4 on STOCK motor with a td06 slap’d on. Can easily do low 10’s now.
Full 5 page ”stage one” write up in number 33 HPI. Will see the “final” write up in an up-coming HPI.
Dyno sheets can/will be available when the car has had a tune up. The car is making 500+RWHP, but is unable to put more then that to the rollers (no traction), so the true amount us un-known
https://www.sau.com.au/forums/topic/22461-500hp-s13/
Originally posted by N/A®
Sorry,
Can you please clearify, you added GTR turbo's, Manifold etc to make it a twin turbo RB25 right? Was this a easy straight forward bolt on?
Thanks for the info.
No, they are modified GTR items, made to suit an rb25, and highly modified HKS 2530 turbos, No its not easy, or cheap.
https://www.sau.com.au/forums/topic/22461-500hp-s13/#findComment-487271
