Make: NISSAN
Model: SKYLINE R33 SERIES 2
Milage: 105,000
Transmission: MANUAL
Colour: WHITE
Complied? YES
RWC supplied? (WRITTEN OFF NEEDS TO GET PINK AND BLUE SLIP)
Currently registered? YES
Price: $6000 ONO
Contact: MARSHALL 0406533126
Comments / Modifications: FULL EXHAUST INTERCOOLER BLEED VALVED LOWERED BODY KIT DRIFT WING
if u would like images of the damage feel free to email me at [email protected]
damage to the car is ... passenger side front guard , door , rear quarter and small bit on rear bar, front right shock and steering back right shock... needs new wheels... although I have the stock wheels still...damage due to hitting a gutter front on at 80 km's
engine and interior of car is perfect
https://www.sau.com.au/forums/topic/224891-r33-series-2-write-off/
I WAS DRIVING NEXT TO THIS CHICK.... SHE MERGED INTO ME... AND PUSHED ME UP THE GUTTER..... NAH NO DAMAGE TO FLOOR PAN....
hittin a guttter at 80k will do that sort of damage, dont know why you blokes are questioning that,
suspension costs is most likely why it was written off...
any damage to floor pan mate?
spoke to a guy this morning on here works for prestige smash in lansvale.... said around 4-5 to rapair the damage
ouch. what happened? have you got a quote on fix price?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
