hey all,
over the past few months ive been fiddling with my suspension set up. (im a compulsive fiddler), im work in the trade(mecanical) so do you blame me AND i live near some great roads.
ive changed,
ride height - started at front 355mm, rear 345mm to 350mm front, 340mm rear (centre to top guard)
sway bar settings - front full hard them full soft then medium now full soft, rear medium now hard
alignment - played with toe out 1mm front to 0 toe and 2.30 neg front camber to 3.00 neg front camber, rear at 1.30neg and 1m toe in per side.
rims - different offsets, from 22 to 12
my final set up has been known to me for some time thanks to so much imput from here but i just wanted to find out for myself,
finnaly it drives like a gtr should,
ride height- front 350mm rear 340mm
sway bar- front full soft, rear full hard, 3 hole type
alignment- front 3 deg neg camber, 5 degree caster, 1mm toe out, rear 1.30 deg neg camber, 1mm toe in per side
rims- 12 offset.
tyres allways the same re55.
just wanted to share my enjoyment and my compusive fiddling, some changes have been good and some have been down right crap. :ermm:
Edited by robbieraver
https://www.sau.com.au/forums/topic/224945-r32-gtr-suspension-set-up/
changed it today, much better, but toe out i didnt think that would work, but it dose, especialy the 5mm higher in the rear.
That's a well tested (since 1999) set up, so I am not surprised that it works :D
Cheers
Gary
Hi sorry little of topic i have a r32 gtr and its lowered quite alot with Tein monoflex coil overs can someone please tell me what is the right aftermarket part to replace the rear upper camber arms, i was thinking of buying JIC brand but dont know if i get the bush type or pillow ball uppermount type?. I want to dial a little of the camber that i got when i lowered the car.
Cheers.
hi ive gor 32gtr with g4 coilovers (10kg, 8kg i think) and tension rods swaybars arriving midweek, the car handles bad. low speed bounces in the rear around roundabouts and other sharp corners on gas (smooth road). what sort of setup should it have, i have increased the bound a little that seemed to smooth it out over bumps a bit. where r u measuring the ride height from i think one of my guards is a little off in shape. the ride height if i measure from the guard to centre wheel is 325mm front 320mm rear, front camber is 1.4 not adjustable do i need adjustable arms, front toe 2mm total, rear camber 2.20, rear toe 3.3mm total. what castor should it be set to havnt aligned yet wiht tension only just put in(drives the same wiht them). i need some hepl dont know what to set at.
Wow the Tein monoflexes come in 7kg front and rear the car handles awesome and to me and all my friends surprise is very comfortable for the street, i think your spring rates are a little to hard for the street, i am going by my experience with mine as before i purchased the coil overs i did alot of research on spring rates and generally anything over 7kg was going to be hard and bouncy for the street, all the best can anyone help me with my previous question on the rear upper camber arms please.
cheers.
i hate to say it but dump the g4's and get something else to start with. the spring rate and valving rate is WAY too harsh,the group buy for 32 gtr's with eibach springs is as about as goodas its gets with out spending big $$$$$$$, then raise the car 25mm front and 25mm rear.
2mm toe, is that in or out.
front camber, not enough, 2.30neg, offset bushes or arms required.
rear camber, too much back it off to 1.30 neg to flattern the tyre out for grip, you may need arms or offset bushes.
rear toe, 3.3 toe in or out.
caster, as much as you can get. 5-8 degrees would be nice.
i cant get rid of the g4s i know they are vey harsh but ive only got them recently, going off the alignment printout it doesnt say negative so i assume it means out front and rear, going for the max castor does that twist the upper control arm or clap out the bushes, camber pins are near the cost of cheap adjustable control arms arnt they? if u set the damping on the g4s below about 10(out of 36) they can harldy control the spring so they have to be set fairly hard.
the problem with alot of W/A machines is there all not the same, eg toe in (+) wheel pointing in, toe out (-) wheel pointing out, going from what you have said its toe in, try (-).5mm toe out per side front, skylines hate toe in (+), makes the steering lasy/no feel and gtr's have aprox 2mm of (+) bump steer. rear, try 1mm of toe in (+) per side, it will keep the rear in check, some people perfer that feel.
caster, it will twist the upper arm but not to that extent, im running 5 degrees perside with noltec uper arms and no problem YET....
G4's, go ebay, they are just too hard the wheel will not be incontact with the road properly, and suspesion is there to controll the wheel,
bilstein and eibach, the eibachs are only 4kgmm rear and 5 kgmm front, this combo is very well controlled for the track and hills.
At 325/320 you will have lots of bump steer, particularly at the rear. The camber curves will go postive due to the upper control arms being past parallel (to the road) at static height. Combine the bump steer with the camber moving towards positive as the suspension compresses and you have a recipe for a distinct lack of traction. A front camber kit ($183 on the Group Buy) and 2 rear camber kits ($123 on the Group Buy) will fix the camber problems. As Robbie said get some caster on it ($110) and flog those G4's to someone else.
BTW at 325/320 you will be losing around 25 bhp due to the accute driveshaft angles.
Cheers
Gary
Cheers.
This thread explains my thoughts on adjustable arms
http://www.skylinesaustralia.com/forums/Wr...tml&hl=arms
To which I would add, if you change the rear upper control arms you have to also change the traction arms and adjust them in tandem. Otherwise you will end up with a gross amount of bump steer. Plus you should keep in mind that aftermarket arms still use the standard (soft, rubber, worn out) bushes in the uprights (hubs). So you have a solid spherical in the inner joint and mushy rubber in the outer joint, not a good mix.
The rear camber kits we use (Noltec or Whiteline) can be used to replace all of the buhes with polyurethane and enable adjustment of BOTH the upper control arm and the traction rod, hence removing the above problems.
Cheers
Gary
i called just jap today, i got the g4s off them, they said the front spring rate is 12.1kg and the rear is 7.2kg, i can get softer springs one of them said put the rear springs on the front and get 6kg for the rear, then another guy said the car would be to soft on the front reckoned it would be no good. what do u sk and robbie think about changing the spring rates on them. i dont want to sell them coz i wouldnt get much for em cant afford new coilovers. i know they are basic.
simply, dont do it,
the g4's will be valved to suit a small window if spring rate, plus or minus 2kg in rate, when you go outside this specified rate the shock cannot control the spring.
a basic working of a shock is there are shims in the shock body that let oil flow thru at a certain speed, this inturn lets the spring be contolled, this also is matched to the spring rate and that is why you cant put any spring on any shock(very short version)
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
