i'm hardly ever home at the times they are open ... i may go back to unisa gym ... hey can u go get pricing for a years membership there?? if its good i might consider joining back and just going on the weekends and weekdays i will go somewhere else cause its too much bother going to town just for the gym ...
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-486925
I think the pricing is roughly the same. I think UNISA students it's a bit under $100, other uni students probably $140 and for others (like me) costs me $170/year.
You should try find a gym where you can buy sessions. Like 30 visits for $XXX. That way it saves a bit of money, and you can go whenever you like. Not worth paying for a year if you only go once/week. Well, it's not bad actually as it's damn cheap anyway.
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-486935
I am talking about the one in the city. I know a few of the people behind the counter there, but not Brett. I don't think the Mawson Lakes UNISA gym pass can be used in the one in town because my friend has membership at Mawson Lakes and he has to pay whenever he goes to the one in town.
The one in town is pretty small, but has enough range of free weights to keep you amused. If you want to go for classes, I'd go somewhere else seeing that they only have 3-4 classes/week. They may have more when the warmer weather comes round, but not entirely sure. The gym is usually pretty packed, especially on mondays.
https://www.sau.com.au/forums/topic/22520-gyms/page/2/#findComment-490179
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
