ok i have a few things for sale that i have accumulated over the last year or so..
OEM nissan front brake pads - coupe
- these are from NON-BREMBO brakes and will fit 03-05 V35's and 350z's
- not sure if they will fit the sedan or not
- they are almost brand new and have been used for only 1 month
- i instaleld them with a set of RDA rotors, and the rotors did not like them at all and squealed. i ended up changing to rb74 pads
- the brake specialist suggests to use these with the stock rotors to get the stock pad performance without squealing
- these were bought new for approx $100 from riverside infiniti in the USA
price: $75 + shipping
OEM V35 coupe rearview mirror
- original rearview mirror from the V35
- removed to fit a homelink mirror
- in perfect condition
price: $30 + shipping
OEM in cabin air filter
- this is the in-cabin filter located behind the glovebox
- removed from my car with 25,000kms to put a new one in it
- condition very good, probably didn't need to install a new one as they looked almost the same!
- bought the new one for $80 shipped from teh USA from riverside infiniti
Xenon-look interior globes
- for the V35 coupe, not sure ifthe same on the sedans
- these are light globes to replace the festoon globes in both the bottom of the doors, and above your head in the centre
- they are designed to give a whiter light than normal yellow bulbs
- not as white as LEDs but have superior reliability to LEDs which are notorious for failing
- bought new from eBay for $50 in a set of other globes
price: $10 + shipping
i might have some more things to add at a later stage. feel free to ask any questions.
pictures are below
I am located in New Farm, Brisbane and am happy to ship anything interstate
cheers,
Warren
https://www.sau.com.au/forums/topic/225430-for-sale-v35-and-350z-items/
Sorry for the naive question, but what nav setup? Is there a way to use the existing screen and have working nav?? Sorry if it's been covered before: I've been busy elsewhere, and haven't checked in for a while...
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
