hey all
i think my cat converter is on the way out, there is a rattle coming from it!
what should i pay for a 2nd hand cat? and what do i need to look out for ?(i know rattles are not good) lol
any advice would be good
thanks
cara
https://www.sau.com.au/forums/topic/225481-second-hand-cats/
Go for a decat through silicone intakes, $39.99, it looks like a cat but has a straight pipe through it! or go a r34 GTR car, much higher flowing than most high flows (thanks scandy) not sure on a price tho
How old is the CAT?
They typically should last a reasonable time. My last was a touch under 150,000km's before it began to break up.
IF its blowing out quickly consider having the tune checked; of which may also be related to your recent spark plug tip melting experience. :S
If something is off dropping another cat on to it is a waste of money as it will just break again.
when i got the car i was told the cat looked new, the thing with the spark plugs has been sorted, ended up being that the nos leaned out in two cylinders.
i didnt have an O2 sensor for awhile, in the last service it was discovered that it wasnt working, but i dont know how long before that it had not been working for.
there is no point in me getting a high flow cat, there are no benefirs, i have already been told that by John Keen, if it was turbo then yes it would be worthwhile, but cause im all the way naturally aspirated, there is just no point in me spending the money on something that is not going to benefit.!
If all issues are sorted just bang the guts out until you have the $$ to grab another cat. all though not really recommended legally. :D
Cubes, ive heard that banging the guts out causes too much turbulence in the housing, thats why decat's are used? I dunno, i think i read it somewhere :)
if you dont wanna spend the money why not just get a pipe to replace your car? ^_^
Hi Cara,
I have a second hand cat sitting around it was only used for one week on my old 32 before having a race cat put on the car.
Send me a pm and i am sure we can make a deal for it.
Hey Shaun, I have a second hand cat that sits around all day too and eats too much sleeps too much and sprays my bike weekly.
No offence to any of my fellow Asian Bro's out there but does anyone have a chinese restaurant that may be interested.....they're supposed to taste like chicken!! :)
asian dont take cats, they eat dogs.. :cool:
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
