hey guys recently purchased a r33 gtst and it came with an Alpine AVN5504D double din deck in it. its a touch screen unit with cd,dvd,md,tv,gps,radio functions. its in perfect condition but it wont work :cool: . i have a message in japanese saying that its asking for the sat/nav dvd which was translated by my japanese neighbour. none of the other functions will work untill i get a hold of this cd i presume? i asked alpine for an oz version of this deck and its like $3500+ :) . has anybody had similar issues with their imported decks or know anybody who would be able to fix these problems? any help would be greatly apprechiated.
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/
ITS A ECLIPSE AVN5504D
sorry for the typo
hey guys recently purchased a r33 gtst and it came with an Eclipse AVN5504D double din deck in it. its a touch screen unit with cd,dvd,md,tv,gps,radio functions. its in perfect condition but it wont work sad.gif . i have a message in japanese saying that its asking for the sat/nav dvd which was translated by my japanese neighbour. none of the other functions will work untill i get a hold of this cd i presume? i asked alpine for an oz version of this deck and its like $3500+ blink.gif . has anybody had similar issues with their imported decks or know anybody who would be able to fix these problems? any help would be greatly apprechiated.
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/#findComment-3972169
yep, bin it. the system is different thant he local AVN6000. see a couple of these a month. I do have a navi disc for one but its not going to help you in your quest for a cheap dvd/nav system. the DVD is locked to region 1 I believe.
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/#findComment-3976802
Chris is correct.theres not alot you can do with it im afraid.
Jack
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/#findComment-3977042
im not too worried bout the dvd n stuff i just want to be able to play music on normal cd's?
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/#findComment-3977608
  • 5 months later...
Hi guys,
I'm a bit new to all this so I need some advice, after bringing my car with me from the Uk fitted with an Alpine INA-N333R I found that the navi unit needed a new map, so far I haven't been able to find one. Does anyone now of a way forward allowing me to keep this head unit? Only at present I'm using a Navman unit...
Thanks for any advice...
https://www.sau.com.au/forums/topic/225535-alpine-avn5504d/#findComment-4302444
  • 3 weeks later...
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
