Heres the question...
i got a budget of around $800 - $1,000 give or take a hundred or so for a system for my r33... what you guys rekon i do? i'm talking the works, if subs where, where for the amp, how many speakers, etc... what would you guys do in my case...
i already got a deck- kenwood.... 50w x 4 blah blah blah... seen it in JB-HIFI for $499... nothing drastic in that... bought it when i got my car about 2 months ago not knowing what i would do (if anything) to the audio system for the future... the stock skyline speakers are finished, gone, done...
so what you guys think i should do? just interested in afew suggestions diff to mine...
https://www.sau.com.au/forums/topic/22557-advice-for-a-sound-system/
When talking high quality systems that includes a sub and amp, a $1000 budget is a little small even given the fact that you have the deck.
But if that is the absolute maximum I'd suggest this (which is one we have done many times too just quietly)
Boston FS-60 6" splits at the front (doors and kicks)
Audison SRx4 amplifier
Jl 12W0 subwoofer
Stinger cable.
You would probably end up spending $1200-$1400 when you factor things like installation and sound deadening in but I tell ya what, the end result would be well worth it. :O
if you never plan to run subs, you can get a good set of splits and a pair of 6x9s and a small 4 channel that will do the job. A very cheap stereo i did for a guy, 1 x Alpine Type S Dual voice coil, 1 Alpine M200, Wireing kit from Autobarn and a set of cheap splits running off the head unit that was in hte car, cost, $600 neat, but that was building the own box out of timber that he supplied. It goes off its head too, the box is ported btw
Garys Car Radio - High St, Preston
For around $1100 I got (installed in my old vl)
2 x Clarion 10" Free Airs
2 x Clarion 6" Door Splits
1 x VNET2100 AMP (For Subs)
1 x VNET450 AMP (For Splits)
1 x Custom sub box install with 2 x 3" port holes to the parcel shelf. This was the best sounding stereo system I had heard for its price. It would outperform installs of 2k+
I already had my own head unit (just like u)
Yeah Fhrx has the idea,
Buy the best stuff you can afford, even if you need to lay buy.
AMP, SPliTS and Sub. Buy them in that order.
I wouldn't recommend a wiring kit for a Skyline, you don't need half that shit.
You'll need RCA cables long enough to go from the front to the back. About a metre of BIG power wire and a Metre of BIG earth. (get the same size)
And you'll need speaker wire to run from the amp back to the front speakers.
Check out the other threads in here.
Hey guys, just starting to look into the audio thing, so pretty unsure of all the specifics, but... can someone simply explain the concepts of chanels on an amp with reference to simply powering a sub. I was originally thinking of just putting in coax 6" in the front (or 6.5") and 6x9's in the the rear shelf, but i think i am turning away from the 6x9s and go the sub. I am at this stage just planning on having an amp for the sub, and just run the components off the head unit. Basically i want to check that there is no point in getting a 4 channel amp just for the sub, and what the consensus is on component speakers and needing their own amps. Bit long winded, probably as a result of me not really knowing much on the topic.
Cheers.
ofoofoo .. sub is always best for bass .. can't be beat with normal speakers ... if u're stuff for space ... go a 10" ... as for amp ... if its just for bass .. then get a monoblock amp ... they are designed just for subs and they are much more efficient for subs than a normal amp so u win with price/performance there ... i'm currently running my splits of the head unit right now and it works pretty good ... but if u really want it to sound good then get an amp ... an example of a good cheap system would be a cheap alpine monoblock ... about 300 ... 10" alpine type S ... thats about 150 maybe .. 50 for the sub box if u make it urself ... that will give u good bass ... forget the back speakers ... spend big on the fronts ... that will be a killer system .... good luck
Cheers hippy. Hopefully will spend my money in the right places - looking at DLS stuff. i think if i am going to spend the cash on decent speakers, should probably go an amp for the fronts. hoping to do it all for about 1600 (including head unit). i'll let you know.
cheers, was thinking car toys. Dont really know of anywhere else which has a good range of quality speakers (i need to check out some place called GT audio or something also). Have worked it out with friend - looking at two CA20 amps (1 x 170 WRMS), a classic series 12" sub, and hopefully the Reference series 6.5" components for front. add a couple of hundred for wiring/box, and with a bit of bargaining looking probably at $1700-1800. Then there is just a whole heap of work to do.
at the moment i cant do much but sit at home (doctors orders), but yeah i will come out (to a cruise) at some stage. Once i add some more stuff.. :D oh mine is black - absolute washing pain in the arse; true to what they say, the first black car you own tends to be the last black car you own.
$1000 isn't gonna buy you much in terms of quality really...but i guess what i'd do is
alpine type R splits or some focal polykevlar's 2nd hand - $350/300
or some Hertz splits new ~ $300
2nd hand Alpine Type R Sub or some RF punch's- $250
$100 for wiring and sub box building (4Ga)
Vnet 4100 2nd hand Amp - $300
or jaycar 4x100rms amp
no rear speakers, no point.
$1000 exactly
put in 100rms into each speaker, and put 200rms into the sub
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
