i also notice the nissan tag on your floor mats.. i have the same tag, it looks funny and always gets flipped over! i have been contemplating cutting mine off but can't bring myself to do it..
Ripped mine off the minute i got the car home.
There's no purpose in it.
FFS sake, they could have sewn it under the mat.
It's like keeping those "100% wool" tags on the sleeve of a suit. :blink:
Has anyone got the same sticker?
I cant see any 'adjuster' knob under the seat,just wondering if it even exists??
Got the sticker. Isn't the adjuster one of three 'buttons' on the other side of the seat (ie, seat hight, forward/back, and the thigh adjuster??
Yeah i was thinking that too, but it's a funny place to advertise it, and it doesn't say the other adjusters anywhere either.
1 seat forward and back (for long or short legs)
2 seat up/down (for tall or short people)
3 seat recline/incline - actually this may be it-it kinda takes the weight off your legs/thighs when you raise it back....nice one scorp i guess this must be it.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
