Ok so I'm getting really pissed off now, and before I put a fist sized hole through the LCD, I'll see if anyone here can help out.
Its pretty simple really...I've got a ps3, HDMI cable and a Samsung 19" LCD (LA19R71BX: Link to specs)
The PS3 works fine in full HD downstairs on the 46" Samsung M8 LCD, but people are usually watching that TV so I need to get it working up here as well.
Basically I plug the HDMI cable into the LCD, switch on the PS3 and LCD, and hit the 'source' button to get it into HDMI mode, where all I get is a blue screen and the message 'mode not supported'
Considering the TV is HD, has a HD input, I see no reason why it shouldn't work!
Hopefully someone here knows why and can sort it out for me.
Cheers
https://www.sau.com.au/forums/topic/225815-ps3-samsung-19-lcd/
Holy shit... it only has a 8ms refresh rate. I didnt even know they made that anymore
i think it may be that you've set the PS3 to read at a cetain output level on your 46 incher, and now that you've moved down to a possibly smaller output level TV, your not getting the signal. You may have to plug it back into the bigger TV and screw with your settings.
a tech head may be able to explain it better, but im pretty sure thats teh problem
Edited by ctjet
I took it back downstairs the last time I tried to connect it up here...the resolution setting is set to auto so in theory it should really adjust itself to the TV its being connected too...seems pretty stupid if you have to set it up on the other TV everytime you want to move it from one to another.
I don't know much about the PS3 since i don't have one, but that TV says it's HD ready. It just doesn't have a full HD res, which shouldn't matter, it should take the 1080i signals and display it anyway. Doesn't the PS3 do 1080p? Maybe the TV doesn't like that, it wants 1080i?
Screen Size 19"
Resolution 1440 x 900
Dynamic Contrast Ratio 600:1
HD Ready Yes
LCD 100Hz N/A
Try this Dezz.
1) Set the TV to HDMI mode
2) Connect the HDMI wire to TV and PS3
3) Hold the power button for 5 seconds until you hear 2 beeps
switch between the different HDMI channels if u have more than 1.. and look for a picture...
you dont have to disconnect anything in the back of the tv... just make sure the HDMI is the only video output attached to your ps3.
2) The secret video reset
One of the most annoying aspects of the PS3 are its video settings. Take it up to the bedroom portable or round to a friend's house and there's a good chance that you won't be able to see anything on screen because your 'new' TV is running at a different resolution or using a different cable connection. And - because you can't see anything - you can't change it.
Until now. Shut down your PS3 then restart by pressing and holding the power button.This will reset your PS3 to its most basic 480p graphics mode so you'll be able to see enough to choose RGB SCART, component, HDMI or whatever from here.
gave it a go, but holding down the PS button did nothing, apart from switch it on initially.
I tried it 2 ways, once with the PS3 off, pressed the PS button (which switced it on and continued to hold it waiting for 2 beeps), got nothing.
Then with the PS3 already on, I held it for more than 5 seconds and still got nothing.
none of that reset stuff worked for me, but just now I've managed to make it work on this TV...in the most ridiculous way possible.
I took it downstairs, switched it on, and then went through the steps to get to the display settings auto setup part...I wrote down how many times I had to press each button (X, 4 left, 9 down X, X, X, X) which gets to the auto display setup. Then I brought it back upstairs and did it all again blind.
If thats what it takes to get it working every time then Sony are a pack of absolute retards.
You can try to set the tv to 60Hz, commonly used with game consoles these days, also the tv is only capable of 720p display output so set ps3 to that on your larger screen 1st, as you are already de-scaling the picture resolution from console as tv is 1366x768 maximum display resolution not 1980x1080p as your larger monitor is capable of. If all that fails get on the line to samsung customer support 1300# and they will talk you through setup :)
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
