hey all.
my skyline is pinging around 2000rpm threw to about 3000rpm dose any one have any idea what could cause this i have changed plugs. running v power. put some octane boost in. im thinking possable the timeing as put it on comp an the timin angle is 5%.7
thanks
martin
https://www.sau.com.au/forums/topic/225862-skyline-pinging/
i just wounderd if any one had experinced the same or similer prob.its hard to describe exactley wat its doin inless u drive it.
would you recomend anywere or no anyone in newcastle area??
thanks for all the advice.
martin
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3980039
15 degrees is what the timing should be at.
If its at 5 degrees, deff get it checked out by a mechanic who looks after imports.
Dont go to nissan as they will charge you thru the roof and probably wont know what to do since they dont work on skylines everyday like other work shops..
Or you could do it yourself and perhaps borrow a timing gun from someone to check.
Edited by siddr20
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3984784
My car is totally stock save for a nismo rear muffler and I have my boost solenoid on a switch. If I run 7psi down low it also pings at about 3000RPM.
Higher octane fuel helps, I've also heard that a better exhaust will improve cylinder scavenging and might help this problem.. planning to do it anyway so will see if it helps.
Already checked ignition timing, changed fuel filter, and fitted 1 heat range colder plugs and makes no difference.
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3987501
Always used 98RON, I wouldn't use anything less either. It is definitely happier on 100RON.
Timing is 15 degrees, plugs are NGK BK6RE something somethign.. i think the standard heat range is 5 so it's 1 colder. Standard 1.1mm gap.
I have used consult software to try richening the mixture or retarding the timing, and in both cases when I get it to the point where pinging stops the car is running like a dog. So I just leave the boost switch at its normal value so I'm only running 5psi in the midrange and 7psi up top (which it is fine with).
I am thinking that a new exhaust/cat will provide less restriction and hopefully push my load points a bit further which will make the ECU richen things up slightly. I think "taking it somewhere" will only produce one of two outcomes - they will retard my timing further making it run like a dog or recommend a PFC which is a logical (but expensive) step. Really the only thing I haven't tried is replacing the fuel pump, and I don't think that's the problem because the pinging is worst in the midrange.
https://www.sau.com.au/forums/topic/225862-skyline-pinging/#findComment-3990066
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
