WTF happened to the spoiler???? put it back on! looks like a p.o.s without the spoiler and wheels!!!!!!!!!
still have the spoiler i took it off while i was cleaning underneath it, havnt had the motivation to put it back on lol....
im sure the new owner will buy it some nice new wheels :D
i still have that spoiler at home if u want it too ross! its just sitting there collecting dust :D
  • 1 month later...
Need this sold.... No swaps
$6400
now has
- k & N pod filter
- new drive belt
- new windscreen wipers lol
- new coolant
- pair of 33 rims with it
has rego til the 2nd month in 2009 i think
0404 331 770
as you can see in pic it needs new bonnet gas strut things if u dont like using a piece of wood as seen below these are $60 off ebay
  • 1 year later...
Hello
I signed up to ask a question about this car (I know it has been long since sold), but I can not PM you since my post count is less than 10
Can you state what bodykit, rims (including tyre size) you had fitted to your old Celsior?
The reason being I would like a similar look for mine, but all of the body kit's I've looked at look cheap and tacky. Your looks pretty good.
Have you lowered yours on coil-overs?
Many thanks
John
i imported this car originally, never found the brand of bodykit, found one that looked similar, but cant remember now.
the wheels were veilside andrews, 18x 10.5 in the rear, had 275 tyres on them, cant remember the offset around +20 from memory?
originally it had 255s on it for stretch. think the fronts were 9.5 with 235 on them.
hey dude, i owned the car after jangles and before josh, wheels were veilside andrew racing dish in 18x10.5 on rear with about 265's, the rears are still around somewhere, think they are spares for a drift car, the fronts got trashed.
yeah no idea on bodykit, jap special, google celsior bodykits and see what you find.
it was on stock bags with an aftermarket ride height controller, seen in the pic with the wheels on it. but josh put coilovers in it as he had some problems with the bags.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
