Honda's answer to the Nissan GT-R and Lexus LF A hit the ring earlier this week when our spies caught a black and white clad NSX prototype powering round the circuit. We had been questioning what kind of performance we can expect from Japan's newest supercar but now those questions have been answered after information has surfaced that Takeo f*kai, CEO of Honda demanded the development team build an NSX that is faster than both its Japanese rivals.
That would mean a lap time of at least 7 minutes 28 seconds would need to be achieved around the Nürburgring , that will certainly be a challenging task to undertake. Honda are going a little further upmarket than the GT-R with the package found under the hood with a front-mid mounted 5.5-liter V10 engine producing in the region of 550 ponies and 420 lb ft of torque.
Maximum efficiency for the engine will be achieved with a cylinder deactivation system when the car does not require all of its power such as at low speed. An eight-speed paddle-shifted automatic transmission is expected to pass the power to the wheels via a new version of Honda's Super-Handling All-Wheel-Drive system (SH-AWD), and use lots of aluminum in its construction to keep weight down. Unfortunately, by the time the NSX arrives, the GT-R V-Spec will have moved the bar again.
The Honda/Acura NSX is still 2 years away but it will be interesting to see if they can once gain become Japan's ultimate supercar.
LOVE THE SOUND
https://www.sau.com.au/forums/topic/226162-ceo-demands-to-be-faster/
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
