Hi all,
When my car arrives i plan at some point to increase the boost :)
I am wondering what would be my best plan of attack. Noting that i wish to have very good control over the boost while i am still running stock turbo. As usual, cost restrictions are in place but i will stretch my funds for the right setup.
1: Buy boost guage and a simple boost controller e.g. turbosmart bleed valve or 2 stage controller
2: Buy AVC-r or similar boost controller and use it as both controller and guage.
I know its up to me in the end, i am just after a few opinions to guide my choice.
Any help would be greatly appreciated
Gary
https://www.sau.com.au/forums/topic/22636-boost-control-options/
I Just had a Turbosmart eBoost fitted today.
Im very happy with it so far.
Lots of features, fully programmable, 3 levels of boost at the press of a button (You set waht you want).
http://www.turbosmart.com.au/boost_control..._electronic.htm
hi how are ya's i have a 180sx with a SR20 all pretty stantard but it has
a apexi air filter and 5zigen cat back exhaust, pretty poo hey but its ok for now. im interested in fitting a boost controller and a boost gauge. so can anyone help me and let me know what kinda power the car is putting out and how much it will put out after it goes up to about 13 psi and is it safe with out touching the computer.. cheers for ya help .....drifta180
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
