  • Replies 120
Guest KILLER-T
Well im glad someone knows what happend to it because i dont it might of been the tune it could of been me thrashing it to much or it might of been the usless shop that did my first cooler.I couldnt point the finger at anyone i would of liked to but im still not 100% sure why it died.All i know is it cost alot to get fixed :)
Its running about 322 at the moment, as soon as we put the bosch 910 pump in it richened up the top end of the fuel map again :) So far the turbo's been on for 3 weeks, maybe 4 weeks now... havent had any issues, pulls like an ox, until the feel the stock ecu pulling the timing out and retarding and then dumping in a heap of fuel. I cant wait to get the wolf3d in, it will make such a difference, go for a ride in paul's car thats a monster, breaks traction so easily and pulls nice and hard. Steve at sst reckons 350hp @ treads is fine for the stock internals, just make sure you service it regularly... but with that sort of power you can be living on borrowed time, its not like our engines are spring chickens... mine is 8-9 years old now and coming up to 85,000km's.
Oh if you want 350hp at the wheels I'd go the same way as paul with the tubular manifold and the GT30. His exhaust housing is tiny compared to mine, but it makes good HP on 13-14psi... you dont want to run high amounts of boost on the stock internals, best if you can keep it under 1 bar or 15psi.
Well grant is gonna be doin my turbo and hes pretty convinced that 350 is very easily possible with stock manifold and lowish boost. I'll be getting my wolf in the next week or so. Lookin forward to it. My car is runnin stock boost nd ecu at the moment. F#ck its slow!!
Mate I'm still running the stock manifold, so it wont be an issue. I reckon get a GT30 with a wastegate attached to the exhaust housing like mine bolt it onto the stock manifold. It will be laggier than paul's cos of the manifold but it will cut your costs by about $1200-$1400 dollars. Mine makes max boost by 4600rpm, it isnt a lag monster, but it aint like a stock turbo either :)
Yeah, full boost at 4000ropm, but we've taken timing out to limit the power, so I'd expect it to spool sooner when we can give it a more aggressive tune.
I'm definately doing the internals ASAP, but finances need to replenish.
Killer, Thanks mate, I'm happy with the result, and excited about what it will do with internals, cams and more boost:D
People that want a good upgrade on a standard motor running
300rwhp should look at a 25/30 HKS bolton or a 25/40 to do it easy.Pauls car has a soft ignition map and lots of fuel so i think
if the motor is in good condition it will last but he wants more so a build is the only way to go.
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
