I believe the R32 GTST rear subframe (i.e. diff, axles, hubs and brakes) can bolt up directly to the rear of the A31 but what about other Skyline models. The reason I ask is because a buddy and I have sourced a rear subframe but we're not quite sure exactly which model Skyline it came out of, what we do know however is that it has a LSD as well as 2 pot brakes with "NISSAN" grooved in the calipers and HICAS.
What I want to know is if there are any problems to look out for when attempting to bolt up the entire subframe as a whole. Is it simple as pulling unbolting the old non HICAS, regular 2x3 bolt diff non-lsd sub-frame and bolting in the new one (i.e. no fabrication involved)?
OR
do we have to make adjustments?
I'm new to this so please bear with me.
All help appreciated.
Edited by Conrad 2NR
r32 rear sub frame bolts straight in, just get a hi cas lock bar. when i did it the only proplem i encounted was the back brake lines needed to be made longer, only cost $40, and if you unclip the original cefiro flexable brake lines they will strech to reach to get you by. by the time you stuff around doing a back brake conversion it is quicker an easier to swap the whole sub frame, you can sell the old one aswell. but some say one of the bushes wear out. good luck. install pineapple bushes while you do it.
Thanks for the recommendations. About swapping non-hicas rear subframes and doing 5 hole conversions...in my country (Trinidad & Tobago) it is relatively easy to get an entire rear subframes from an older model Skyline (my mechanic has one lying around his yard doing absolutely nothing).
I will go the route of using the R32 rear-subframe and hopefully it should bolt straight up without much hassle.
Again, thanks for the heads up.
    • Price seems pretty good to me. Also seems a hell of a lot cheaper then buying another vehicle that only ever gets used for towing.  I'm a long way from you mate, I'm a couple of hours out of Brizzy.
    • New [400]Z, they're available in manual and you don't have to worry about parts scarcity.
    • Just planning to have the wiring neat and hide as much as possible.
    • The sodium acetate, mixed with citric acid, doesn't actually buffer each other. Interestingly though, if you used Sodium Acetate, and acetic acid, THAT becomes a buffer solution. Additionally, a weak acid that can attack a metal, is still a weak acid that can attack a metal. If you don't neutralise it, and wash it off, it's going to be able to keep attacking. It works the same way when battery acid dries, get that stuff somewhere, and then it gets wet, and off it goes again breaking things down. There's a reason why people prefer a weak acid, and it's because they want TIME to be able to be on their side. IE, DIY guys are happy to leave some mild steel in vinegar for 24 hours to get mill scale off. However, if you want to do it chemically in industry, you grab the muriatic acid. If you want to do it quicker at home, go for the acetic acid if you don't want muriatic around. At the end of the day, look at the above thumbnail, as it proves what I said in the earlier post, you can clean that fuel tank up all you want with the solution, but the rust that has now been removed was once the metal of the fuel tank. So how thin in spots is your fuel tank getting? If the magazine on the left, is the actual same magazine as on the right, you'll notice it even introduces more holes... Well, rust removal in general actually does that. The fuel tank isn't very thick. So, I'll state again, look to replace the tank, replace the fuel hanger, and pump, work out how the rust and shit is making it past the fuel filter, and getting into the injectors. That is the real problem. If the fuel filter were doing its job, the injectors wouldn't be blocked.
    • Despite having minimal clothing because of the hot weather right now, I did have rubber gloves and safety glasses on just in-case for most of the time. Yes, I was scrubbing with my gloves on before, but brushing with a brush removes the remaining rust. To neutralize, I was thinking distilled water and baking soda, or do you think that would be overkill?
