gday guys i have a r32 gtst and the rb20 has ful shit its self
my question is--
to rebuild the rb20 with fogies ect ect from top to bottom or put a 25 or 26 in...
if i was to put a 25 or 26 in can i stil get it roadworthy just as easy///
cheers
neew opinions serious ones///
trav
"ful shit its self" doesnt really describe to the people in the know on this forum what happened to your engine.
If uve thrown a rod through ur block, they may as well go a 25, but if its a less major problem, they maybe rebuild will be all you need.
Post up details of what you think has gone wrong.
....Im not being a smart arse, ull just get a better response if you post up more info
thanks for the input guys..
basicly i have a hole in piston 2 and bent valves
im contemplating on putting a 25 in but im in vic and pretty sure id have to get an engineers to get it road worthy..
my other idea is just to buy a bare 20 engine...
so yeah just got to think..
30 is the go...mite be a little hard to pass ur road worthy etc tho!
depends there is the old, grind the 30 engine number off and stamp your 20 number in trick. If you use a 25DE head, then it will look exactly like your 20, bar being 30mm higher-something which i doubt any of the blokes which check would notice.
Or look around for a cheap blown 25 and rebuild that, then sell your 20 to recoup a little of the cost.
It's not like there are mint 25's lying around.
Don't forget there are a few extra issues involved in a 25 conversion. ie. Use 20 or 25 tranny? Gearbox mounted in differently for 25, also which ECU to use? You can use either, depending on your setup and if you want to run NVCS, or even a Power FC.
Edited by R338OY
yeah think i have figured a source i can get a bare 20 motor dirt cheao im going to slap that in for now just to get it going then get roady and in the mean time build a 25/30 then wen complete put it in :(
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
