Item:
Blitz return flow intercooler kit
Unknown
Condition:
Very good
Price:
$750 + postage/freight
To Fit: (What car)
HCR32 - slight modifications
ECR33 - direct bolt on
ECR34 - direct bolt on
South eastern suburbs, Melbourne
Contact:
PM
Email/MSN [email protected]
Call/SMS 0416 623 381 - No private calls
Comments:
I put up an ad for this intercooler kit before but some of the information I put up was inaccurate and because I can't edit the thread I thought I would start a new one as there will be too much confusion with the old thread
The intercooler kit is a blitz return flow kit with piping to suit R33 & R34 – direct bolt on with no modifications required (no cutting, drilling etc) and because the intercooler kit is a return flow kit it doesn't cut or alter the chassis design of the car there for making it legal as long as you have only one induction mod (VIC requirements)
This kit will bolt straight onto any R33/R34 and uses the factory holes in the chassis and mounting points on the bonnet latch to secure it, the kit has all the brackets to get it fitted up, as it would have from new
The intercooler kit will also kit R32 but the piping is slightly different so you will need to either change the mounting height of the cooler OR change the length of the factory pipes in the engine bay where it meets the guard (longer silicon joiner) but other than that it will bolt straight up
I have trial fitted the R33/R34 pipe work onto my R32 and its all pretty much the same, only the one pipe that goes to the intake cross pipe sits a little to far from the pipe in the engine bay so a longer joiner is required other than that everything else bolts up as normal
Intercooler core has been professionally powder coated in a colour called texture black and looks very neat and stealth when fitted up to a car, I was using it on my car with the R32 piping but I bought another blitz return flow intercooler kit exactly the same but the kit is to suit R33/R34.. Reason I bought the kit was that I wanted a polished core again due to retaining back to the standard airbox so making the intercooler kit legal. I have kept my R32 piping kit and am now selling my core with the new R33/R34 piping kit as the cores are the same
If you want the core polished up, you could get the powder coat stripped off and the core polished but there would be no reason to wreck the good powder coating job
Intercooler flows great, fitment is the best and it's so simple to fit up. It literally takes only a few minutes once you have the front bar off the car, everything lines up 100%
Any questions feel free to ask, I will get pictures up of the whole intercooler kit tonight when I get a chance
Will freight anywhere in Australia at buyers expense
Thanks
https://www.sau.com.au/forums/topic/226681-blitz-return-flow-intercooler-kit/
Comes with all necessary piping, brackets and silicon joiners required for installation onto any R33/R34, straight bolt on and everything lines up 100%
Pictures below, as you can see it needs a clean but is practically in new condition
Thanks
    • Yeah i found that alot of parts can be wrong or "very" hard to get the real right one. I already bought some brakes years ago on me "old" GT calipers and they were wrong too 😄  I told them too. Even send them pictures...but they said "EBC catalogue has them on my car... So i dont know what their answer will be. I call monday them and let them know that they are really not on my car. If they were they would be already on a car...
    • Welcome to Skyline ownership. Yes, it is entirely possible parts websites get things wrong. There's a whole world of inaccuracies out there when it comes to R34 stuff (and probably 33 and 32). Lots of things that are 'just bolt on, entirely interchangable' aren't. Even between S1 and S2 R34's. Yes they have a GTT item supposedly being 296mm. This is incorrect. I would call whoever you got them from and return them and let them know the GTT actually uses 310mm rotors. Depending on where you got them from your experience and success will obviously vary.
    • Hi...a bit a "development" on the brakes. I spoke to the guys where i get brakes from...and they are saying that 296mm EBC are for R34 GT-T. I then went to their site: https://www.ebcbrakes.com/vehicle/uk-row/NISSAN/Skyline (R34)/ and search for my car(R34 GT 1998 - it has GTT brakes) and it show me this USR1229 number and they are rly 296mm rotors... So now iam rly confused... The rotors i have now on the car are 310mm asi shown... So where is the problem? Does the whole EBC got it wrong or my calipers are just...idk know what?
    • Oh What the hell, I used to get a "are you sure you want to reply, this thread is XX months old" message. Maybe a software update remove that. My bad.
    • This is a recipe for disaster* Note: Disaster is relative. The thing that often gets lost in threads like this is what is considered acceptable poke and compromise between what one person considers 'good' looks and what someone else does. The quoted specs would sit absurdly outside the guards with the spacers mentioned and need  REALLY thin tyres and a LOT of camber AND rolling the guards to fit. Some people love this. Some people consider this a ruined car. One thing is for certain though, rolling the guards is pretty much mandatory for any 'good' fitment (of either variety). It is often the difference between any fitment remotely close to the guards. "Not to mention the rears were like a mm from hitting the coilovers." I have a question though - This spec is VERY close to what I was planning to buy relative to the inboard suspension - I have an offset measuring tool on the way to confirm it. When you say "like a mm" do you mean literally 1mm? Or 2mm? Cause that's enough clearance for me in the rear :p I actually found the more limiting factor ISNT the coilover but the actual suspension arms. Did you take a look at how close those were?
