My Stagea failed compliance today because of a tailshaft center bearing. I can get it cleared today if I find another tailshaft to put in before 4pm.
Problem I have is my car is a RWD RS which is rarer than awd I believe.
If anyone has a spare automatic tailshaft they can spare for a couple of weeks for a carton, or sell to me, please call me asap on 0401 512 776. My names Kevin
Or even if you know somewhere that can get me one. I can't stand waiting another 2 weeks to re-book Regency.
THANKS!!!!!1111 :)
yeah nobody has any, genuine nissan ones are like $320 and wont be here till Monday.
Anyways the compliancer found one at City Dismantlers to borrow to get it through regency, then I need to find a replacement
Bad news is they didnt swap it over and get back down to Regency in time, so I go another week without my car. Been waiting over 3 months since I handed over cash now.
Edited by Silhouette31
Yeah I think I'll wait till it goes through regency before I tint the windows :s
We do window tinting at my work so thats not an issue, but definatly on the top of the mod list.
Anyways, found new center bearing and it should be passing Regency on Monday.. Definatly can't wait, I can't help but keep looking at the photos :(
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
