I have obtained a very limited number of component kits to make the Noltec Adj Front Upper Control Arms for R32GTST, R32GTR and R32GTS4. These are the "Motorsport" version which features reduced flex under heavy duty track use as experienced when using "R" type tyres and/or slicks. There looks to be only 25 kit sets able to be manufactured, so first in gets them. They are expected to take 3 to 4 weeks to manufacture. Replacement bushes will always be available as they take the standard dimensions.
When they were available from Noltec they were $539 for the pair. The Group Buy price will be $399 including delivery. Please PM the order and, as usual, payment can be made by credit card or direct deposit.
Cheers
Gary
https://www.sau.com.au/forums/topic/226707-noltec-r32-camber-adjustment/
While we are at it I have 1 pair here only brand new in its packaging that i will sell for $320 delivered. Part #N52088
ready to go now. I have taken a photo of it and if you would like a copy PM me and i will send it when i get home tonight.
  • 4 months later...
  • 1 month later...
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
