  • Replies 42
Hello jetpilot.
Need a set of brembo pads for a GTR33.
Really just need the rears for the time being...but if the price is right..lol
Pm me if you can help.
Hi im intrested in just a front set of A1RM Brembo ... would the price be the same at $149 + $12.50 shipping
let me know ;)
Hi mate,
Yep, that's correct, but unfortunately out of stock at the moment. Should have more Brembo A1RM pads in about 4 weeks time.
Regards,
Greg
Edited by jetpilot1986
Hello jetpilot.
Hi mate,
Only got Brembo pads left in HPX, which is the similar sort of performance as Bendix Ultimates, just minus the dust and rotor wear. $149, plus $12.50 shipping for for the rears, or $236 for front and rear shipped.
Regards,
Greg
Hi mate,
Regards,
Greg
Thanks Greg for the quick response.
How do you think the Lucas rate compared to these you are offering?
Do you sell Lucas TRW Pads?
Can't seem to find the part numbers for my car.
Anyways,
I am running Brembo pads front at the moment with RDA rotors.Stock rear.
Replacing the rears with slotted rotors and new pads.
The trouble is at the moment the Brembo pads suck..take a long time to warm up and have scared me quite often.
Car 99% street driven, fairly hard when all warms up that is...lol
No track work..a few 1/4 mile runs..that is about it.
The trouble is there are so many choices...
I am after one that works well when cold...does not fade or explode when pushed hard...has very minimum disc wear, quite and creates little to no dust.
Take care
Tekin
Hi mate,
The Lucas are a very good pad, and will withstand very high temperatures. We peronally used to run the in the rally car because for the price, you couldn't go past the performance. We've now replaced them with the QFM A1RM, which is more of a dedicated performance pad, and its definately an improvement. Although the Lucas will withstand very high temperatures, its still just a very good performing street pad, and not a performance pad as such. Other problem with the Lucas is the dust.
Yep, I think from memory (don't quote me), the TRW's for the Brembo are about $120ish/$75ish front/rear...
If the car isn't being used on the track, then the HPX will be more than enough, whilst providing good cold bite, and minimal dust. With the QFM we often forget that the HPX is the lesser of two pads when compared to the (slightly more expensive) A1RM, but the HPX still has the sort of performance of Bendix Ultimate, or Ferodo DS2500 or EBC Green stuff, but whilst remaining a very good street pad.
If dust is of concern, stick to the HPX. If dust isn't a big concern, then the TRW Lucas is definately a slightly high performing pad, but is quite dusty.
Hope that helps!
Regards,
Greg
Hi Greg,
You don't reply to your emails so:
I have a problem, I just installed the pads on my GTR and there is a very load screech when braking now. This is very embarrassing and quite franking annoying.
No where on the thread does it mention that this is normal, so I can only assume that this is a manufacturing defect? please explain yourself.
Why would this be happening?
Edited by GTR-PWR
Hi mate,
That's unusual! Were they A1RM or HPX pads? How long after you fitted them did it start? Did you machine the rotors? Did you re-fit the original shims? Squeal is caused by vibration between the backing plates and the caliper itself (nothing to do with the pad material itself), and so, depending on machining tolerances, some calipers will do it not matter what pads are in it. Try some Loctite 3 (permatex) on the backing plates as often this is a better fix than the proper anti-squeal stuff.
Regards,
Greg
HPX pads. Started to squeel a few weeks after, it happens under light to medium breaking. Mostly at lights or in car parks when breaking at low speed with lightish pressure. Its very high pitched and embarassing. Original shims and all that jazz.
Why use the loctite 3 instead of anti squeeling stuff? Where do i get it from?
Cheers!
Hi Greg,
Hi Harry,
Sent you the following email yesterday:
Hi Harry,
Sorry about the late reply. We had two public holidays last week so we took the week off and went testing with the team for a few days.
Yours were Brembo's weren't they? Was there any dramas with installation etc.? The pins went through the pads ok, and it all fitted fine? Never had any dramas with them at all previously, so just trying to figure out if there has been a manufacturing error. Screeching is generally harmonics between the backing plates and calipers itself, and nothing to do with the pad material. Due to variances in manufacture of both the pad and more importantly, the caliper, the pads can often get harmonics between them and the caliper, which is the screech. Pad material itself, won't make screeching noises, and can only very rarely make very low speed grinding noises, but that's not a problem we've ever had with the A1RM, and would more likely be a rock in the caliper or something.
If you can, get some anti-squeal, or what we find works well is Permatex (Loctite 3) and cover the backing plates in it before installation. Short of that I can't really think of anything else to do.
Any dramas let me know.
Regards,
Greg
Cheers!
JP??
Hey Greg
Are the deals still in place or has it finished... was looking at the 'HPX Front and Rear Brembo Pads. $110 + $55 + $12.50 shipping = $177.50 delivered!' Is that deal still on..
JP??
Sorry bud. Loctite 3 (or permatex as its otherwise known) is just a non-hardening gasket or sealant that can be bought at most bearing, automotive or hardware store. But pull the pads out first, give them a light rub on concrete, on BOTH sides of the pad. The type of squeal you describe is harmonics between the pad and the caliper, and nothing to do with pad material itself. Did you machine or replace the rotor with the pads?
Hey Greg
Hi mate,
Yep, still got a couple of HPX Brembos on the shelf. Just PM your details, name, delivery address (preferably business) and email, and I can fire you through an invoice with direct deposit details etc. or else credit card over the phone is also fine.
Regards,
Greg
Hey Greg .. still waiting for a your details?
Sorry mate. Myself and the team were down at Phillip Is. for the 6 hour over the weekend, and have only just gotten back in today. Will PM straight away.
Regards,
Greg
hey after a set of front and rear lucas pads for s13 turbo Fronts:db1232 Rear:db325 can you give me a price deliviered to NSW 2069 cheers
Edited by DOCK
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
