Well first a HUGE thank you to Nick. Going out of his way to pick me up, drop me off and scoot me around doing touristy things in Sydney. Without him, I would've spent the night sitting in my hotel room, bored out of my mind.
Secondly, thank you everyone who came and said hello. I had a great night. Wonderful cars, wonderful people, wonderful stories.
Thirdly, here are my pics. Although I have the picture taking skills of an epileptic elephant, so dont expect too much.
https://www.sau.com.au/forums/topic/226734-my-short-stay-in-sydney/
I'll make sure I'll check with you next time i am down and organise my life to revolve around Sl¡m time? :P
Yeah really was 50ty billion times better then doing nothing ;) Thanks again Nick ;)
And it wasnt cold, apparently last night Rocky got down to 5oC :(
Nah nothing really phases me, and I was very, very toned down compared to my usual behavior, so next time I am down you all better be read for.....
SLAYAH!!!!™
**for explanation of SLAYAH!!!!™ please see following video:
SLAYAH!!!!™
Jeez, Cy, if you'd brought that shirt to Sydney with you, you wouldn't have needed a flash for the camera that night! Oh, and I would've needed earplugs.
:woot:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
