Guest Rotary20B
Basically stock GTS-T, full 3" exhaust fron turbo back, high flow cat. Boost controller set to 10psi. Auto.
Car is ok if driving lightly on throttle, if you gradually accelerate its not too bad but put foot down and it cuts out
Read a lot of conflicting advice on here about R&R, airflow cut etc..
Any ideas?
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/
It'll be AFM hitting peak voltage.
AFM sees so much air that the ECU thinks it's failing or something is broken, so it goes into failsafe until the voltages drop back down.
Not much you can do cept get a ECU (and replacement AFM), either piggyback or full replacement. Not recommended to go with a "fuel cut defender" type device since all they do is fake the AFM signal once it goes "out of spec" of what the ECU expects, but AFM signal is used to plot load on your fuel map, so the ECU will start leaning out the engine and cause bad things to happen :D
You can try and drop the boost back down on the controller, its probably going a bit over where you expect it to sit, just bring it back down a PSI at a time till it stops doing it. Also remember air temp affects AFM readings and air density as well, so cold nights naturally raise your airflow in.
Edited by Hell Fire
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993173
Cuts out meaning stops altogether? Keeps going but feels soft? Picks up later?
There threads are pretty common, you need to perform basic troubleshooting
1. Check/clean AFM
2. Check/inspect coils
3. Check spark plugs
4. Check all electrical connections 3 times each
5. Ensure timing is set correctly
6. Back off the boost and see what happens, goes away = R&R
And go from there really.
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993212
Guest Rotary20B
Thanks guys.
Cutting out.. sometimes it just cuts revs altogether, normally happens around 4500 - 5k other times it revs but feels like its making bugger all power.
Sometimes it will rev out, but just feels very soft
Coils are brand new Splitfires, plugs are new, gapped to .8.
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993584
i had the same issue but only wen it was raining turned out to be moisture in the igniter pack. would cut all 6 cylinder car would nose dive but wen i backed off the throttle it straight back to driving normal. never backfired nethin like that wen it cut the spark etc just wouldnt go at all. was a down rite pain in the arse . so another thing for u to check
Edited by skylinekid
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993611
