Guest Rotary20B
Basically stock GTS-T, full 3" exhaust fron turbo back, high flow cat. Boost controller set to 10psi. Auto.
Car is ok if driving lightly on throttle, if you gradually accelerate its not too bad but put foot down and it cuts out
Read a lot of conflicting advice on here about R&R, airflow cut etc..
Any ideas?
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/
It'll be AFM hitting peak voltage.
AFM sees so much air that the ECU thinks it's failing or something is broken, so it goes into failsafe until the voltages drop back down.
Not much you can do cept get a ECU (and replacement AFM), either piggyback or full replacement. Not recommended to go with a "fuel cut defender" type device since all they do is fake the AFM signal once it goes "out of spec" of what the ECU expects, but AFM signal is used to plot load on your fuel map, so the ECU will start leaning out the engine and cause bad things to happen :D
You can try and drop the boost back down on the controller, its probably going a bit over where you expect it to sit, just bring it back down a PSI at a time till it stops doing it. Also remember air temp affects AFM readings and air density as well, so cold nights naturally raise your airflow in.
Edited by Hell Fire
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993173
Cuts out meaning stops altogether? Keeps going but feels soft? Picks up later?
There threads are pretty common, you need to perform basic troubleshooting
1. Check/clean AFM
2. Check/inspect coils
3. Check spark plugs
4. Check all electrical connections 3 times each
5. Ensure timing is set correctly
6. Back off the boost and see what happens, goes away = R&R
And go from there really.
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993212
Guest Rotary20B
Thanks guys.
Cutting out.. sometimes it just cuts revs altogether, normally happens around 4500 - 5k other times it revs but feels like its making bugger all power.
Sometimes it will rev out, but just feels very soft
Coils are brand new Splitfires, plugs are new, gapped to .8.
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993584
i had the same issue but only wen it was raining turned out to be moisture in the igniter pack. would cut all 6 cylinder car would nose dive but wen i backed off the throttle it straight back to driving normal. never backfired nethin like that wen it cut the spark etc just wouldnt go at all. was a down rite pain in the arse . so another thing for u to check
Edited by skylinekid
https://www.sau.com.au/forums/topic/226752-r33-gts-t-rr/#findComment-3993611
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
