Hey all,
Im in need of some help!
On my GT-R R33 I will be running a GREDDY PLENUM which is 100mm Entry and my intercooler is an Apexi Drag version which has a 100mm Exit on the plenum side...im not going to be running Blow off valves (Please dont ask me why as i just prefer it that way)...
I wanna buy the GREDDY 100mm Plenum side pipe work to suit the greddy plenum etc...But the issue is it only comes with 2 pipes! Does anyone know if this Pipe kit is all i will need to connect the plenum to the Intercooler, Or will i need to make a pipe replacing the Standard BOV section? Whats the go?
Here is wat comes in the pic:
Anyone with experience using this know???
https://www.sau.com.au/forums/topic/226771-intercooler-pipe-work-need-help/
i hate to ask but why would you not run a bov , you no what the purpose of one is, obviously not if you are considering not running one.....must be cashed up and prepared to replce compressor wheels at regular intervals.
Hey all,
I do know why BOV's are used!! I dont run BOV'S with the set up i do for my T88's, I have never broken a Compressor wheel or ever had any problem for that matter...But i may change my mind as this one is mainly for the street...I normally don't use one due to the fact in between gears it doesn't lose much Air if i lift my foot between a change!!!
At the End of the Day its 'Each to there Own'! So please no more talk about BOV's please!!!
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
