This is an EOI, if you are interested in my short/long motor with or without turbos let me know.
This rb26 is out of my r32 and has down around 8 - 10***k's
Bottem end
Forged bottem end,
r33 gtr crank
Head
Cams
ported
polished
Turbos
HKS25/30s x 2
If your interested let me know and i will give more details.
Keith
https://www.sau.com.au/forums/topic/226834-eoi-my-rb26/
hi guys thanks for the pm's,
Didnt expected any this soon. I will give you guys more info later tonight.
Dont have a heap of time ATM.
Regards
Keith
If i sell the bottem end i wont be going rb26 again.
If i sell the engine i might not go an rb at all :woot:
https://www.sau.com.au/forums/topic/226834-eoi-my-rb26/#findComment-3997685
lol, i have a Windsor and a 6 71 blower :blush:
But i'm not sure what engine yet. not even sure if anyone's going to buy the engine or if i will sell it.
Have to see what happens when i get back to everyone. Sorry it wont be tonight.
https://www.sau.com.au/forums/topic/226834-eoi-my-rb26/#findComment-3998478
330 odd rwkw's at 15.5 - 16psi. The engine was built with 26-28 psi in mind.
Did a compression test on the weekend. 125psi + or - 5psi over them all. And that was just putting the compression tester in by hand.
This engine hasnt yet had its performance tune, Its currently on its running in tune.
I was advised to put 20k on the lot. But i would prefer just to sell it as a short motor.
Make an offer if your interested. Or pm me for me details on the build
Edited by BNR32t
https://www.sau.com.au/forums/topic/226834-eoi-my-rb26/#findComment-4002655
