Before I decide whether to sell or not after changing my mind about fitting them, I'm looking to see if there is any interest in my 18" x 9" ROH Drift R rims.
They are still in the original boxes, with sticky protective plastic sheet over the rim face. No tyres.
Retail is around $480 - $500 per rim.
Offers???
https://www.sau.com.au/forums/topic/22693-expression-of-interest-drift-r-18/
if you had put this up about 4 weeks ago i would have bought them in a second! i just got some other 18s after not being able to get drift R's
they look awesome the Drift R's
Bump
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
