Sold to Sanousie at $195.00 + pickup *SOLD*
Basically as the topic states. Would be fantastic for a first car as it comes with everything required (no need to go out and buy $90 worth of batteries) and also other parts to fit in the future.
Only ever driven around an office against BitCharG's for a total of two battery charges worth of driving as I work in an environment where we deal with cars day in day out, so it was only natural to organise an office race off.
Would like to sell as an entire package if possible. Located in Sydney but I'm sure that AustPost can cater for interstate buyers.
Comes with all original manuals (still in packet), box, display case, cones etc (all still in packet).
The only slight modification made to the vehicle is on the front bar where excess material was surgically removed to allow better clearance.
Details as follow -
1 x Kyosho R34 Nissan Skyline GTR (Silver) + Remote Control
1 x Kyosho X-Speed Motor
Part #MZW8V(still in packet never fitted)
1 x Kyosho Packet of Wide Tire Set
Part #MZW17-20 (4 Tires still in packet never fitted)
8 x Digitor NiMH HR6 1.2V 1700mAH AA Rechargable Batteries (for Remote Control)
4 x Digitor NiMH HR03 1.2V 700mAH AAA Rechargable Batteries (for Mini Z)
Make an offer ..... Pictures available on request.
For more information either PM, e-mail to [email protected] or call 0403 44 33 44.
Pics will be available tomorrow (gotta get to work to get them off the server) ....
Neo, these are a little more expensive than a Bit Char-G but I purchased this instead of one .... Much bigger, faster and more fun.
Also range on the remote is huge ...
initialD : Maybe, I'll see if people buying the car want the motor, if not then you'll be first on my list for it.
I'd probably have to set reserve for the lot at $200.00 .... considering new price of crappy Mini-Z's (Toyota Echo) is $199.00, and remembering that the batteries for this thing almost cost $90.00 alone.
If your interested feel free to view the Hobbyco Website (http://www.hobbyco.com.au/product_groups/s...hp?grp=212&sid=)
You'll see that better models like the Evo VI go for $269.00, so your certainly getting a bargain at $200.00 ...
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
