Hi guys,
I bought a just jap hard pipe kit for my GTR and am having some problems getting the first pipe on. It doesn't seem to fit. Has anyone else hard this problem???
When i put the silicon part just over the lip of the pipe at both ends it is also considerably shorter than the standard pipe(about 2-3cm. Is it possible that they gave me a another GTR's pipe instead???
Here are some pics of the installation as close to getting it clamped properly as i could. It works as long as you don't make boost and then it pops of.
So i'm just after other peoples experience as this doesn't seem like the right fit.
https://www.sau.com.au/forums/topic/227015-ic-hard-piping-kit-32-gtr/
The logical solution would be to give them a call and if there is a problem they will fix it up for you.
From your pictures it looks like a case of poor installation to me.
They are exactly the same as the HKS hard pipe kits and are a perfect fit, several people on this forum are using them.
Yeah i will call them now but i just wanted to make sure that it should be a perfect fit.
Yeah the installation was bad because the pipe did not reach properly.
yeah i used one on cats car with no issues.
Yeah i rang them up and they told me i had a 33/34 pipe.
Is it only the one pipe that is different or all of them??? Just so i don't have to bring the everything back when i don't have to.
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
