I know its not everyones cup of tea, but Parklife is back for 2008!
Parklife Adelaide - TICKETS ON SALE MON 14th JULY 12pm
Parklife Adelaide
Prices range from $91.00 - $101.00
Performances
Saturday at 12:00 pm on 27-09-2008
Venue Botanic Park | South Australia | Australia
Description
As the sun begins to break through the winter clouds and the temperature starts to rise, so does the anticipation among the true party crowd as they gear up for the event that will kick off the summer festival calendar in truly unforgettable style: PARKLIFE. From small beginnings in 2000, PARKLIFE has evolved into a national institution renowned for delivering cutting-edge line-ups of incredible talent from around the globe. In 2007, the PARKLIFE National Tour proved to be the standout success of the calendar year, showcasing what many regarded as one of the most diverse, eclectic and ground-breaking line-ups ever assembled to a combined crowd of over 100,000 people across the country. Now in its ninth year, PARKLIFE is as much an Australian icon as the eucalyptus trees under which it was first staged, and once again in 2008 will be bringing an unrivalled array of fresh and experienced international live acts and dj's to Adelaide, Melbourne, Perth, Brisbane and Sydney.
So who is coming? :D
www.parklife.com.au
Edited by Damo_R34
https://www.sau.com.au/forums/topic/227030-parklife-2008/
  • Replies 64
Posted Images
Could be decent. I'd go for Dizzee Rascal, Diplo, Blackalicious... the rest I don't really recognize aside from peaches...
bit pricey tho. I'm goin to Devo next month, will see if I can justify the expense ;P hopefully there arent too many mongoes drugged off their yar danketies, or idiot bouncers, or cops for that matter. festivals can suck for that reason
-D
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-3996643
nice line up, i'll definitely be there!
It's good for us to get a festival like this on a Saturday for once, but of course the catch is the AFL grand final is on the same day... Not that i have too much to worry about as a Port supporter...
Lookin forward to Metro Area, Jesse Rose, Dizzee, Diplo, AND great to finally see the Plump DJS in Adelaide! Theyve skipped this town every year theyve been down under. If only they came here in 2004 when their sounds were much more appealing to the masses...
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-3996959
2MANYDJs
PLUMP DJs
BLACKALICIOUS
METRO AREA
FAMILJEN
VAN SHE
BAG RAIDERS (live)
GRAFTON PRIMARY
AJAX
MIAMI HORROR
SOULWAX
DIZZEE RASCAL
DIPLO
DOES IT OFFEND YOU, YEAH?
FAKE BLOOD
LADYTRON
ELEKTRONS
DRAGONETTE
VAN SHE TECH
HAWNAY TROOF PEACHES
MARTIN SOLVEIG
JESSE ROSE
NEON NEON
XXXCHANGE
YUKSEK
BOY 8-BIT
SLYDE
SNOB SCRILLA
+ many more
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-4016263
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
