I know its not everyones cup of tea, but Parklife is back for 2008!
Parklife Adelaide - TICKETS ON SALE MON 14th JULY 12pm
Parklife Adelaide
Prices range from $91.00 - $101.00
Performances
Saturday at 12:00 pm on 27-09-2008
Venue Botanic Park | South Australia | Australia
Description
As the sun begins to break through the winter clouds and the temperature starts to rise, so does the anticipation among the true party crowd as they gear up for the event that will kick off the summer festival calendar in truly unforgettable style: PARKLIFE. From small beginnings in 2000, PARKLIFE has evolved into a national institution renowned for delivering cutting-edge line-ups of incredible talent from around the globe. In 2007, the PARKLIFE National Tour proved to be the standout success of the calendar year, showcasing what many regarded as one of the most diverse, eclectic and ground-breaking line-ups ever assembled to a combined crowd of over 100,000 people across the country. Now in its ninth year, PARKLIFE is as much an Australian icon as the eucalyptus trees under which it was first staged, and once again in 2008 will be bringing an unrivalled array of fresh and experienced international live acts and dj's to Adelaide, Melbourne, Perth, Brisbane and Sydney.
So who is coming? :D
www.parklife.com.au
Edited by Damo_R34
https://www.sau.com.au/forums/topic/227030-parklife-2008/
  • Replies 64
Posted Images
Could be decent. I'd go for Dizzee Rascal, Diplo, Blackalicious... the rest I don't really recognize aside from peaches...
bit pricey tho. I'm goin to Devo next month, will see if I can justify the expense ;P hopefully there arent too many mongoes drugged off their yar danketies, or idiot bouncers, or cops for that matter. festivals can suck for that reason
-D
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-3996643
nice line up, i'll definitely be there!
It's good for us to get a festival like this on a Saturday for once, but of course the catch is the AFL grand final is on the same day... Not that i have too much to worry about as a Port supporter...
Lookin forward to Metro Area, Jesse Rose, Dizzee, Diplo, AND great to finally see the Plump DJS in Adelaide! Theyve skipped this town every year theyve been down under. If only they came here in 2004 when their sounds were much more appealing to the masses...
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-3996959
2MANYDJs
PLUMP DJs
BLACKALICIOUS
METRO AREA
FAMILJEN
VAN SHE
BAG RAIDERS (live)
GRAFTON PRIMARY
AJAX
MIAMI HORROR
SOULWAX
DIZZEE RASCAL
DIPLO
DOES IT OFFEND YOU, YEAH?
FAKE BLOOD
LADYTRON
ELEKTRONS
DRAGONETTE
VAN SHE TECH
HAWNAY TROOF PEACHES
MARTIN SOLVEIG
JESSE ROSE
NEON NEON
XXXCHANGE
YUKSEK
BOY 8-BIT
SLYDE
SNOB SCRILLA
+ many more
https://www.sau.com.au/forums/topic/227030-parklife-2008/#findComment-4016263
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
