Jdm S14 Parts For Sale (vic)
For sale: S14 JDM spec goodies
Item Condition and Price:
1. S14 Dash - 106K on clock. Very good condition, with small surface scratches on front face which could easily be polished out. - $240
2. S14 Thermo Fan - Good condition, mounts onto the S14 radiator - $30
3. S14 Steering Column - Good condition, with Key (not factory) $120
4. S14 heater module - Excellent Condition - $150
5. JDM S14 front end (LCA's, power steering rack, x-member, power steering rack, castor rods) - Good condition - needs a bit of a clean up, rack isn't leaking (hence I haven't cleaned it up!) - $450
6. JDM Power steering pump - Good condition $145
7. JDM airconditioning pump - Good condition $145
8. S14 radiator - excellent condition with one small area where fins are bent (only just visible in photo) $140
Extra Info:
I can ship smaller items, but the front end, I think it would be best if you live local (Melbourne), and come and pick it up.
Contact Details:
Nik
Pm me or reply back to this message
Items are located in Bayswater in Eastern Suburbs of VIC
Delivery & Conditions of Delivery:
Will post at the expense of buyer
Pictures:
See below.
Hi,
Was just wondering if the "JDM spec" parts are similar or exactly the same as Aus spec parts?
Good question, I'm pretty sure most of them are the same considering the S14 200SX was fully imported.
The only reason I said they were JDM spec, is that they came from a Japanese S14 and not an Australian one.
  • 3 weeks later...
  • 10 months later...
  • 5 months later...
  • 2 months later...
 Share
    • Hi mate, I have never had an issue with the odometer in mine (450,000+ klm now) and can't remember another post about it. Still, your description of the likely cause sounds spot on, so an electrics repair is probably the next stop.
    • Cheers. I more want it quieter with the varex open. I only have the varex closed when i start up and roll out the driveway to keep everyone happy on days i take the car to work at 5 AM or come home late. So just a mod muffler will do tge trick? Something like that would require a retune hey?
    • I was going to say generally speaking if it's like 80k+ miles since the valve cover has been replaced you don't even attempt to just replace the gasket. The valve cover itself will likely be warped and it will continue to leak after replacement, just not as severely. The valve cover PCV diaphragm can also tear and create a major vacuum leak. Welcome to BMW life. My friend's 2006 330i was t-boned and totaled out so he also just got a 335i so I can add to this thread now.
    • Hi all, For my '98 260rs... The odometer LCD occasionally turns blank or gives me only the bottom half or top half of the numbers. It's intermittent, which leaves me to believe it's a dead solder or loose wire somewhere. The odometer itself works. When the screen comes back, kms have been added to the trip and overall meters. A couple questions: Is this a known issue with the Stagea? I didn't see it pop up in my quick search, but that could be my searching skills. How accessible is the LCD screen in the cluster? I'm hoping it's a remove and replace type situation versus cracking open the whole housing. I'm hoping you all can narrow some of my initial troubleshooting. Any experience or opinions would be helpful.
    • Yeah. Seeing the finish line must be quite the motivation. Good on you for sticking with it. Understood about the model choice. Also, totally get the challenge with sourcing parts. Based on your handle, I'm just a few hours south of you. All the little things I've bought so far come with $30 shipping, even if it's just stickers for the boot!
